Question about Home
My showerforce shower (970,970,972-t) was becoming more difficult to stop water. I have to try very hard to tighten the knob to stop water completely. I have removed the cartridge (sk 1400-2) with the thermostat etc however these items sprang out of shower onto floor and I do not know the correct order to replace them. There are 4 items, the large brass cartridge, a small black and red narrow tube with circular middle piece (possibly a thermostat)(brass circle in black end), a spring and another piece with a white pronged pointed area set into a clear yellow short cylinder ( there is a short broad spring inside this). I would like to know how these pieces fit together to go back into the shower and do i need to purchase a new one to fix my dripping problem?
  • john whittaker Nov 19, 2010
    was helpful but unfortunately too late.
    Guru:
  • 642 Answers
Apologies for the crude diagram.
Parts in order of assembly:
1 - Spring
2 - Washer
3 - Shuttle(your white pronged part)
4 - Wax capsule/Thermostat(your black and red tube)
5 - Washer(fits over cartridge)
6 - Cartridge
The dripping is caused by the cartridge seals leaking leaking.
You can replace the cartridge as a complete unit or disassemble it, clean all parts(with descaler) and replace the seals, which is considerably cheaper
Posted on Nov 19, 2010
  • Rene Rossouw
    Rene Rossouw Nov 19, 2010
    Diagram for cartridge disassembly:
    1 - O-ring
    2 - Half cartridge
    3 - Adjusting screw
    4 - O-ring
    5 - O-ring
    6 - Non shut-off head
    7 - O-ring
    8 - Flow nut
    9 - PTFE washer
    10 - Head
    11 - Circlip
    12 - O-ring
  • Rene Rossouw
    For some reason the end of the diagram got cut??
My handheld shower where the hose attaches to the tubing spirts out water when i turn on the shower when it is upright in its holder. help
These are finger tight fittings... DO NOT OVER TIGHTEN.
If it is installed correctly there should also be an
"ANTI-SIPHON" valve there... to protect your health
and that of every person likewise attached to you water pressure system...
you could clean it wit vinegar... or "lime-away" type
calcium remover... or REPLACE IT.
If enough time has passed since its installation "water deposits" can cause the valve to not perform "optimally".
At least get a spare... it is no more difficult than putting on a garden hose.
Hope this helps
Oct 17, 2016 | Home
I went to take a shower this morning and the water was ice cold. For more than twenty minutes the water ran and never warmed up. Are there common things to check my hot water heater for in this situ
There is an adjustment knob to control how hot the water can become. There might be a problem at the tap (however, if this is the case, you would still get hot water everywhere in the house). If the entire house isn't getting hot water, and the knob is set at the hottest water, you probably need to get the hot water tank replaced.
Feb 04, 2015 | Rheem Tankless Hot Water Heater...
Can't take a bath!
The diverter can become clogged with mineral deposits. The handle will have to be removed to gain access to the diverter. The diverter can then be disassembled as necessary to determine what needs to be done to free it up.
Jan 17, 2014 | Home
My shower control valve has become hard to operate and squeaks when turned. It is only about 4 months old. Sounds like it need a lube job.
shut off the water. remove handle and unscrew the cover that holds the internal parts. inspect ball for wear. purchase some valve stem grease at the hardware store.lightly lubricate all moving parts. reassemble but only tighten it snugly. do not crossthread!
Sep 14, 2010 | Danze Home
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Mira thermostatic shower water dripping from bottom of casing
Switch off the power supply to the shower at the consumer unit, it will probably have its own individual circuit breaker as it is such a heavy user of power. Try now to switch the shower, it should be dead and that is good. Remove the control knobs and remove the front of the shower unit. Check the electrics with an electrical screw driver to make sure that there is nothing that will cause electrocution. Trace the source of the leak, the most likely place is the compression joint to the mains water pipe. Tighten the compression nut until the dripping stops. Dry everything off with a paper towel and check there is no sign of further leaking. Reassemble the front with the knobs and switch the power back on.
May 27, 2010 | Home
The all in one tub/shower faucet constantly flows. What can I do to fix this problem? Now I am a woman, so please make it simple.
Go to home Depot or loew and buy the seat replacement kit for your model of faucett. Your going to have to break out the tools (Philipps Screwdriver and a larger adjustable wrench) The remove the shower knob cover with a knife to access the mounting screw. Remove the screw and then the knob. (STOP!) Go turn off the water for the residence now! Then come back and remove the nut holding the faucett in place. The whole assy will with a little effort will come straigth out at you. Moen isnotorious for having to remove a plate from the bottom of the valve. NOTE the position of that plate and then remove it. Remove all of the seat seals one at a time and replace them with the new ones you purchased. Reinstall the NEW lower plate in the same position you removed the old one. Reinsert the assy back into the valve body. Tighten the retaining nut. Reinstall knob and secure with screw. Replace knob cover. Turn on the water NOW. Enjoy the non-leaking faucett.
Jan 21, 2010 | Moen & One Handle Tub & Shower Faucet
MY TUB KNOB KEEP TURNING AND TURNING AND WILL NOT TURN OFF THE WATER
There is probably a little plastic hubcap on the knob. You can pop that off with a butterknife. Underneath there should be a screw. If that screw is very loose, tighten it and it may solve your problem. If it almost fixes it, but you can't turn the knob very hard before it slips again, then remove the screw and use a pair of pliers to carefully turn the shaft that the knob was on. If that is not the problem - (which means the knob was NOT slipping on the shaft) then the valve will have to be taken apart or replaced. Make sure you turn the water off (upstream) before you attempt to take the valve apart.
Jan 19, 2010 | Moen 2919 Chateau Two Handle Tub and...
I have a shower tower and the water directional knob has become immovable any ideas?
try CLR to lossen it,remove and clean.This is due to calcium build-up. you may have hard water,have your water checked.
Jul 16, 2009 | Grohe Aquatower 3000 Shower Tower...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Home Logo
1,120 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
