Hello my Wirlpool washing machine makes a scratching noise when the drum is turning during the wash. The noise disappears however when the washing machine is spinning. Would it be worn out bearings?
  • 77 Answers
You would hear the bearings in the spin cycle if it was them ....it would sound like you are at the airport...you will probably find that a bra wire has caught itself inbetween the drum and the tub and is scratching as it goes around.
Posted on Nov 11, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Wirlpool washer wtw5100sq0 tub is vibrating and banging. the drum seems to move all over even by hand
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Whirlpool WTW5100SQ
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Kenmore heavy duty 2 way tumble washing machine
You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
Jan 16, 2009 | Kenmore 44102 Front Load Washer
Noisy washing machine
the agitator transmission may be the noise source because it turns with the drum during spin. may need a new transmission just to stop noise.
Nov 19, 2007 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
