Question about Bosch Dryers
I have a Bosch WTE84102GB tumble drier When I try and use the tumble drier the following happens The following three lights flash Drying Iron dry Anti crease/end The flashing lights are accompanied by the sound of 4 beeps pause 4 beeps pause 4 beeps
  • Matthew Stinson
    Matthew Stinson Dec 04, 2015
    The dryer is showing a fault with PCB, simply remove top lid and re-seat the connection to the PCB. If this still occurs then try and programmer reset, however if this does not work then i'm afraid its going to need a PCB replaced.
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
  • 2920 Answers
SOURCE: My tumble dryer is spinning but no heat.
it sounds like either your heating element went out or your limit switches are bad
Posted on Jan 14, 2009
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Posted on Oct 21, 2009
SOURCE: my hoover maxi 6 reverse air tumble drier has no
The thermal overload has failed. Replace the heater assembly on the rear of the drier, under the metal cover.
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch WTL 5100 Tumble Drier
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
I have a bosch classixx tumble drier, condensing type. When I try turning it on, select levei of dry. Then press the start button I get a bleep, then the 'drying light', 'iron dry light' & 'anti-crease/end...
Sounds as though you need to unplug then empty the water from the water container & the lint box, then definitely open the bottom flap & by rinsing & drying the condenser box gently to avoid damage use an old tooth brush, once all these are complete plug back in & try again, as it will not reset until all these are empty & clear, hope this helps.....
Jan 24, 2018 | Washing Machines
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Jun 01, 2008 | Candy CDC266 Dryer
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Dryers Logo
124 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
