Question about Harman Kardon FL8385 5-Disc CD Changer
The drawer in our Harman-Kardon HD 950 CD player won't go all the way in. It gets to the point where there's about an inch sticking out, then re-opens and tries again. This is a fairly new unit. Is there an easy fix?
It turned out that a CD had slid past the drawer and into the case of the CD player. Once I removed it everything was fine. I should point out that mine is *not* a 5-disc drive, but a single-disc drive, model HD 950.
Posted on May 13, 2014
4 Suggested Answers
  • 112 Answers
SOURCE: harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Posted on Jan 15, 2008
SOURCE: Describe your Harman Kardon CDR30 2-Disc CD
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Posted on May 25, 2010
  • 347 Answers
SOURCE: I have a Harman Kardon CDR2 and the cd drawers
hi jlcady
sounds like the belts need to be replaced. for that the units eject mechanic assy has to be disassembled.
feel free to text for further assistance.
regards
Posted on Feb 13, 2011
What to do for hkhd 950 no disk
Hi, your harman kardon hd 950 has probably a problem with your optical bloc. You can try to insert a clean-up cd or clean-up directly the laser sense cell but if the problem persist you have to go to a repairshop. But take a look at the price to repair maybe the best is to buy a new player. Sorry for this answer and have a nice day.
Nov 09, 2014 | Audio Players & Recorders
Looking for an internal parts diagram for a Harman Kardon CDR2
Where do you live? Sarasota electronic has belts if its wrotten take machine and belt I am in florida
Apr 03, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR2 2-Disc CD Recorder Left Tray Door sticks
these are not rubber bands they are belts and if you do not apply the proper ones you will ruin the motor, but it is the problem
Apr 01, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD ERROR
Good day!
Sharman
TIme to change de device, it is a rotating mechanism, on the CD, or something is broke, remember that this unit are plastic almost all inside.
good luck
Nov 15, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harman kardon CDR 26 cd recorder
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon FL8385 5-Disc CD Changer Logo
191 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
