Question about Health & Beauty
I need a foil for a krups shaver. (flexonic 11) B45777
  • 3422 Answers
SOURCE: Foil for my electric shaver?
HI,
You can get the parts from HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 05, 2008
delgriffith
  • 97 Answers
SOURCE: where can i take my braun shaver for service?
you can buy replacement cutter blocks and foils at walmart...about 50 bucks.
Posted on May 03, 2009
BrittanyP
  • 57 Answers
SOURCE: Krups shaver model 488. Where can I find parts
try on ebay
Posted on Jul 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: Foil for Sanyo Shaver SV-M305U
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
brector3
  • 1610 Answers
SOURCE: how do I remove the foils on my sp 69 shaver and
You will find instructions posted at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_21_9.jpg
Posted on Sep 20, 2010
What is a foil electrical shaver?
Foil electric shaver use an oscillating motion in order to cut hairs through a foil. The blade inside positioned in line and may contain up to four rows of blades. The foil electric shavers are ideal for men who are just starting to shave or men with slow beard growth.
Feb 06, 2013 | Health & Beauty
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
Works sometimes...
Braun Model 8985
It sounds like when the foil is on, there is something causing the blade to 'lock up'. My guess is that the cutter bar between the foils may be damaged and can not move. This would lock everything up. You can check it easily. Take off the foil and turn it over. There is a plastic piece in the middle that transfers the motion of the cutter to the bar betewwn the foils. You sould be able to easily move it back and forth with your finger. If it doesnt move, you will need to replace it. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
If this part does not seem to be damaged, the motor brushes may be worn causing the shaver to not have enough power. Was your shaver running slowly or weakly prior to having this problem? If so, the drive unit will need replaced. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To install, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
Apr 08, 2010 | Braun 360° Complete 8985 Electric Shaver
Need a new foil for model 5479 Braun electric shaver
This particular Braun shaver was made in both a US and European version. They are similar, but take slightly different cutter blocks and foil screens, sooooooo
If you bought your shaver in the US, then you can get a replacement foil here for around $8.00 or you can find another supplier of your choosing.
http://www.ecrater.com/product.php?pid=4997848
If you bought your shaver in the UK, then a replacement is available on Amazon.com (UK site) for quite a bit more in British pounds.
http://www.amazon.co.uk/Braun-Replacement-Foil-Cutter-System1-2-3/dp/B0000X5HPK
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Braun Health & Beauty
Where can i take my braun shaver for service? needs a foil/blade replacement
Mar 28, 2009 | Braun 360° Complete 8985 Electric Shaver
I need to change my Hitachi Phase 4 shaver foil of RM-8670B urgently please. Where can I buy it?
Oct 18, 2007 | Hitachi RM 2500 Electric Shaver
Health & Beauty Logo
88 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
