Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Broken fuel line from gas tank to caberator - McCulloch 16 Inch Gas Chain Saw MCC1635AK
  • 7,733 Answers
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Scooter not getting gas to carb.
Silly question, but are you sure you are getting gas through the line? Could the line from the tank be plugged? How about the tank port?
Is there a fuel shutoff?
May 10, 2016 | Motorcycles
How do you replace the gas tank on a ryo 8548 gas blower
Why are you trying to remove the fuel tank just for broken fuel line?
These can be normally be replaced while the tank in still mounted using the appropriate tools.
As for removing the tank you probably need to remove that starter assembly or may need to fully disassemble the casing.
Oct 04, 2014 | Ryobi Garden
1970 yamaha u5 keeps running out of fuel tank is full
Hi, Anonymous always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
Letting tank get low risks more than just running out of gas
Scooter shuts off when stopping red lights stop signs waiting to turn etc...
1965 Yamaha 50 5 Mate Riders Manual
OEM parts for Yamaha
Yamaha U5 owners manual 3920
Sep 25, 2012 | Yamaha Motorcycles
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Please take time to rate me
Sep 24, 2011 | Garden
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
I was trying to smog my caravan and the fault code P0456 No Description Available came up. What is that?
small leak on fuel system get down by gas tank check hoses check filler hoses pos bad gas cap loose or broken fuel vapor vacume line lines go from radiater to gas tank loose line or clampo or tank to float seal
Jun 18, 2010 | 2003 Dodge Caravan
Leaking Gas on left side of gas tank, can't tell if it's the line
More than likely you have a busted fuel line, or one of the connections from the fuel lines to the fuel pump is broken. If you know how to repair cars, drop the tank and find the leak. If you don't know how, have the vehicle towed to a shop. Driving the car would definitely be a fire hazard.
Jan 24, 2010 | 2001 Chevrolet Impala
Have ryobi 35 head, does not get gas, everything ok. someone said that the gas tank has a filter clogged or line broken. primer seems to be pulling air.
If you are pulling air and you don't get enough fuel, the filter in the tank may either one that is weighted and is just placed on the end of the fuel line. Or it could be one that is attached to the tank with a nipple sticking through and held in place with a ring around the fuel line and pressed up tight to the tank, over the nipple. There is also the possibility that your fuel line is broken somewhere. If you cannot see the break, it would be inside the tank. Good luck,,,Lee
Oct 07, 2009 | Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
The fuel lines pulled out of my 1978 GS550 when I was replacing the clutch cable. I need help hooking them back in the right places. I don't know which are fuel lines and which are vacuum and how they...
You will have two lines coming from the petcock on the bottom of the gas tank. the small one goes to the front of the number one carb, and the larger one plugs onto the fuel rail in the middle of the 4 carbs on the back. The lines that run between the 1 and 2 carbs and the 3and 4 carbs are just overflow lines, so they don't hook on anywhere else.
Jul 13, 2009 | 1980 Suzuki Gs 550 L
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
69 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
