Question about Hotpoint WD62 Front Load Washer / Dryer
Unbelievable...leaking again!!! Got an engineer out to fix the leaking during the spin cycle (sock got stuck in the pipe). First time that has happened since we have owned the machine (5+ years), but now I have a feeling that we have the same problem again, as we are experiencing the exact same symptoms :-( I wasn't at home when the engineer arrived (only my wife was home), so I don't know what he had to take apart to get the sock that was stuck in the pipe, out. Is it a simple task or would be just be a lot better/easier to call the engineer back out? Any help would be very much appreciated. Regards Ron.
  • ron2464 Aug 10, 2008
    Thanks tresilla, I'll give that a go as we still have the leak (yes, I know, I still haven't got round to looking at it :-( ). Hopefully that will fix the problem, and we'll be back to a healthy machine again!
    Ron.
    President:
  • 1,462 Answers
Take panel off at bottom rear. you will see a large diameter pipe going from bottom of machine to pump. undo pipe at machine end - carefull lots of water will come out. sock was probably in this pipe which also holds the filter
Posted on Aug 09, 2008
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
While spinning makes a knocking sound
is that a top load or front load washer?
Feb 28, 2014 | Whirlpool Washing Machines
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
I have a problem with my Kenmore Washer. I have tried everything in this article, and although I got the washer back up and running for a load, it's starting to show the same problem again. The water will...
If a coin goes in the drain line and is the same diameter it can stay in and sometimes flip and act as a flapper. One time it may be open and the next flip and close the line off. Take the line off and try and see if it is obstructed.
Oct 27, 2010 | Kenmore 44072 Front Load Washer
Whirlpool awm 337 does not complete a wash cycle
There is either something stuck in the water pump (rogue sock) - front of machine - bottom right, open the flap, remove the plug and check (p.s. it will drop lots of water).
OR, underneath the machine - where the exit pipe from the drum, you will see a split ring holding on the rubber waste pipe. Behind that is a ping pong ball and rubber seal. Socks and the like do collect here.
It's happened about 6 times to me, have got used to fixing it.
Aug 11, 2008 | Whirlpool Washing Machines
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
Dec 11, 2006 | Zanussi ZWF1440 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
