Question about Cell Phones
I have a Wharfdale Orb Twin phone. One of the handsets is flashing "Warning Batt" when on its stand. When off its stand the display is blank. Changing to new batteries has not helped.
    President:
  • Cell Phones Master
  • 1,932 Answers
This is because the charging battery circuit might have damaged due to which it is not charging the battery.No other go you need to take it to the service people
Thank You
Posted on Nov 11, 2010
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
My magicbox logan twin phone base keeps flashingwhere it shows the battery sign when the phone is place in the stand. the main unit is fine the light stays on. i was just wondering if that was normal.
Hi, I had the same problem. I went to Menu and go to clock / alarm setting. Set the clock. "CL" will disappear and it will show you number of messages on the display! Thanks,
Dec 27, 2010 | Cell Phones
My handset is displaying register HS. kindly provide me the required support to reslove the problem.
Please follow this procedure to register your handset
1. On the base station: press and hold the registration/paging key for min. 3 sec.
2. On the handset: within 60 sec. of pressing the registration/paging key;
Select MENU then Settings then OK then Handset then OK - Register HS then OK -
Enter the system PIN of the base station (the default PIN is 0000). Then press OK.
Registering now flashes in the display.
Registration takes approx. 1 minute to complete.
Thanks for using FixYa. Please do leave a vote for the help.
Nov 25, 2010 | Siemens Gigaset A490 Twin Cordless Phone
Wharfdale Orb Twin Phones i cant get a dial tone or receive calls
hi,
is there network service bar on your phone?
if no,check the antenna of the phone if it is properly fix, if not fix properly, then fix it properly.
if the problem continue go to your phone menu, go to setting and call setting go to bare calls.
if the calls are bad, you deactivate it.
if this still continue then you contact your local service provider.
thanks for using fixya.
Jun 07, 2010 | Lands Phones
The second phone in our Wharfdale atmos twin phone set doent work
how can i check the trasmission oil on a 2005 pontiac sunfire
Jan 16, 2010 | Lands Phones
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
