Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Can't pull the cord...it was running, then all of a sudden died out, and could no longer pull the cord to start, it appears to be stuck
  • 297 Answers
First start by pouring out the fuel in the tank, into a container that you can see through. Is the fuel a yellowish color, or is it blueish? If it is yellowish, someone forgot to put oil in it, and you seized the engine and you wont be able to fix it. Well you could, but it would be cheaper to buy a new one.
Hope this helps
Posted on Nov 12, 2010
My 12 years old Craftsman snow blower suddenly died after hearing a bang. Start pull is stuck. Electric start runs, but doesn't seem to be engaged. Thank you for the help in advance!
I suspect the engine is locked. What is the oil level and condition. You can further investigate by removing the starter housing and try to rotate the flywheel. You can remove the cylinder head to inspect if the piston is moving. I suspect the engine will need to be replaced. The original engine is no longer manufactured by Tecumseh (out of business). You may want to replace the snow blower. This is of coarse a worst case senario
Feb 11, 2017 | Craftsman Garden
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
I operate a 32cc Weed Wacker from Craftsman. It was working just fine, but all of a sudden stopped running and somehow I cannot pull the start cord, it got stuck. Where should I look first before opening...
The first thing I would do is remove the housing for the pull cord and spring to find out why it isn't pulling. That may be the same reason as to why it stopped and appeared to lock up.
Jun 19, 2011 | Craftsman Garden
I have had my mantis for five years. It has always been hard to start. From the very beginning I had to move the choke in and out after it started to keep it from dying after it started. Each year it has...
I feel it might be time to overhaul the carburetter. Clean out all the passages and jets, especially the little screen that is pressed into a hole under the one diaphragm. Clean out the recess for the needle and seat and replace all the gaskets, the valve plate and the primer bulb. Also check the fuel tubes and the filter at the end of the intake tube (if it has one). If there is too much wear on either the choke shaft or the throttle shaft, it may just pay you to replace the carb completely.
Mar 17, 2011 | Mantis Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Engine dies when running. Intermittently dies while running no sputtering or other warning, all of a sudden the engine is off. Mostly happens at lower rpm's. Starts right back up after putting it in park.
first thing to replace and cheapest would be the fuel filter ,if that doesn't fix the problem , it may be the fuel pump . GM fuel pumps are in the gas tank, and they have a built in thermo fuse . when fuel pumps get old 60000 miles or so..the motor in fuel pump starts running to hot and the thermo fuse kills the power till it cools down then it will run till it gets hot again note the cool down time keeps getting longer and longer
Jan 12, 2010 | 1994 Pontiac Bonneville
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
2001 Ford Focus suddenly died
have you tried to wiggle the key when the motor is running and does this duplicate the problem...if so replace the ignition switch.
Mar 29, 2009 | 2001 Ford Focus
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
202 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
