Question about Pioneer SFCRW230S System
My husband has a Pioneer 5.1 surround sound but the subwoofer is having an issue and not working. I think something got broke inside the plug. I am wanting to get him a new subwoofer but I am not sure if I can just buy a different subwoofer. For instance, does it need to be the exact same subwoofer to use with the receiver? Thanks!
    Sergeant:
  • 199 Answers
So the unit that you are currently using is a blue tooth device or is not directly wired up and takes a signal from the amplifier ? If the subwoofer is wired up to other speakers that has the blue tooth receiver unit installed then you should be able to install a different subwoofer but if there is no wires that connect them together then the subwoofer must have a receiving device installed to pick up the signal
Posted on Nov 10, 2017
  • 119 Answers
SOURCE: Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Posted on Nov 04, 2006
SirHanz
  • 145 Answers
SOURCE: subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
I have a vsx44 pioneer and i plug my subwoofer do not work my sub has 2 wires and i have an adapter to plug at the receiver
Is the adapter on the back of the receiver a yellow one (like a tv's red/white/yellow)? And the sub itself is a 2 wire (red/black)? If the subwoofer is just a speaker with no electronics and you answered yes to the first two questions then continue reading...
Problem: New receivers suck and are made for subwoofers that are self powered. The subwoofer input on the receiver only puts out a low signal. The subwoofer itself will amplify the the signal.
Solution: Find a receiver that supports the older subwoofers or do like I did... buy a used 3D surround system for around $10 on eBay, if you don't have one laying around. Be sure to find one that shows a picture of the back so you can verify that it has the 2 wire inputs and supports a subwoofer. Once you have it, connect a cable from the receivers subwoofer output into the surround systems input. It will be only one wire so plug it into the left (white) input on the surround box. You can also use a splitter to get both left/right inputs.
This will enable your subwoofer to be used again and will also give you alot more control over it. Turning off the surround sound box will allow you to keep the bass off when needed. You will also gain individual volume control over your subwoofer this way. I hope this helps!
Mar 01, 2015 | Pioneer Elite 7.2 Channel Network Black AV...
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Feb 11, 2010 | Pioneer VSX-453 Receiver
No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Jul 23, 2009 | GE Ultrasonic 2.1 Subwoofer Computer...
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Jan 12, 2008 | JVC TH-M505 System
Pioneer SFCRW230S System Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
