Question about Denon DRA-685 Receiver
I cant get any sound to come out of the receiver. I checked that the speaker wires are not touching. if it is in protection mode how do I get that turned off
    Novelist:
  • 87 Answers
Good start checking your speaker wires. A better test would be to disconnect them entirely in case there's a short inside the speaker itself. Keep the volume WAY down when you power back up and see if it runs for a while. If it does, then you do have a short somewhere - probably inside speaker. If it trips off, you might want to think in terms of getting the problem fixed rather than defeating the protection circuit.
Posted on Nov 12, 2010
Sony str920 reciever protect mode
Check all your speaker wires. Make sure they are not touching the case of the unit or each other. Check the wires at the speaker side as well. If all looks good then you probably have a blown channel. If you have a digital meter you can check the out put Transisters to find the defective channel. There are plenty of parts that would need to be replaced if this is the case. You would need a service manual to find all of the replacement parts needed. Good luck to you.
Jun 05, 2016 | Sony Audio Players & Recorders
Protect mode
Check if speaker positive and negative terminals are not connected to each other creating short circuit, PROTECT MODE occurs when speaker wires touch each other.
--SS.
Oct 14, 2013 | Sony Str-Se501 Stereo Receivers
My fisher-RS939 audio stopping getting out through the speakers and do I get it out if the system is in protect mode
Normally when receiver keeps entering protection mode it means wires are crossed or touching somehwere. Double check all speaker wire connections at the receiver and speakers. More than likey the positive and negative wires are touching at one of the terminals.
Jun 19, 2011 | Fisher RS939
Speakers made popping sound and now receiver is in protection mode
It sounds like you have some wires that are touching cause the reciever to protect itself. Go over and check all wiring and make sure you have nothing touching. Unplug device while you are doing this and then when done plug back up and see if that fixed issue.
Jan 31, 2011 | Denon AVR-1801 Receiver
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
The receiver turns on and immediately goes to standby
The unit is going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 18, 2009 | Denon AVR-5700 Receiver
8001 Receiver keeps going into protect mode. What
Fastest way to check the receiver is to disconnect all speaker wires at the receiver and turn the unit back on. If it does not go into protect, your receiver is ok and you need to check all wires and speakers. If just one piece of braid on a speaker wire touches the other, it may not shut off immediately, however, as you turn up the volume the current level rises in the wire and creates a short. Thus, shuts down the receiver. If you need further help troubleshooting, post a comment and I can walk you thru it. Hope this helps.
Aug 16, 2009 | Audio Players & Recorders
Sony STR K840P, protect mode is flashing,no sound,nothing come out. When starting every thing is fine for 20 or 30 seconds and the "protect"start to flash and nothing geht anymore,everything is blocked
This is a classic problem. One of your speakers is miss wired and or your speaker wires positive and negitive leads are touching. Check all connections from the back of the reciever to the back of the speakers to make sure your positive and negatives are correct and that none of the wiring is crossed or touching one another.
Jul 24, 2009 | Audio Players & Recorders
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Denon DRA-685 Receiver Logo
114 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
