Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin
We opened up the trap and besides water coming out there was a sock stuck in there. How would a sock get down there? The washer shouldn't allow your laundry to navigate out of the drum??? The washer still doesn't spin?? Help.
  • 1 more comment
  • jefbeek Jun 25, 2008
    The washer will agitate, but will not spin??
  • Bigdereck08 Aug 23, 2008
    when wash on short cycle it pops up 5-F all cycles pop on. 28 is the short cycle
  • martinmj1222 Sep 06, 2008
    our washer stopped spinning but would drain after a few minutes took off rear panel to inspect belt. found troubleshooting manual. checked motor for continuity 6.3 ohms on each leg of motor cicuit. when you try to start it it locks then a slight buzz is heard then it unlocks. no error codes
  • 639 Answers
Remove the bottom panel 3 screws on bottom front ,
then you will see a large white (usually) filter access port ,
unscrew it and some water will empty so have rags or pan ready.
remove debris and see that the pump impeller is turning freely.
see that the float ball is loose and floating.
Posted on Aug 30, 2008
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Does not always clear soap , no increase in quanity ,and does not always spin clothes dry ??
The easiest solution to this problem is a sock or other small item has passed out of the washer and is clogging the filter of your water pump. Open the front panel and look at the water pump. If there is a round access door next to this pump, then spread some large towels out to catch excess water then turn the cover of this access door to remove it. Look inside and pull out the stockings/socks/pencils/coins etc that are stuck in there.
This is a 10 minute fix and if you find something big in that trap, 99% chance your problem is solved.
Feb 02, 2011 | Kenmore Elite 45986 Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
My trouble code is#E20 Does not spin all water out before the code comes on restart washer and spins still leaves water in clothes
Just fixed my brother's Frigidaire Affinity front loader with same problem. After checking hoses to see if they were blocked-they weren't-even though that is what the code sheet says...It means that something is blocking/stuck in the filter pump/coin trap. Pretty easy to repair on your own instead of calling a repairman. I am a pretty handy mom and all I needed was a pair of pliers (long nosed) and aPhillips screw driver. Get someone to hold the washer as it is tilted back as far as possible so that you can get a look underneath. The filter pump/trap is in the front right hand corner when looking at the washer from the front. As soon as you look into the hole that is on the bottom of the machine, you will see the black rubber piece. This is what you need to open up. I only opened up the screw clamp withthe screwdriver and then stuck my hand in and pulled out a sock! Then I checked inside with the pliers to see if there were smaller things. WATCH OUT FOR THE SMELL OF THE OLD WATER. I gagged for 3 straight minutes. The smell is disgusting, open a window beforehand. Some water may spill out, hold a towel to catch the fall. Then make sure you put the black rubber back securly on the plastic gray piece it attches to. Make sure all sides are covered. Screw clamp back on. Machine works like new now. First backwash of water (did a spin cycle to get out old water in hoses and machine) stinks.
Oct 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Not draining all the way. slow spin
replace the door switch my washer did the same thing. switch is very easy to replace
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
