Question about Samsung SyncMaster 931B 19" LCD Monitor
MY MONITOR WILL NOT START IN THE MORNING POWER BUTTON BLINKS. THEN AFTER A TIME IT WILL STRT HOUR LATER. COULD IT HAVE ANYTHING TO DO WITH THE LOCK OUT ETC? THANK YOU,JOHN
  • 11,361 Answers
Try it with another PC first and also check the cable since it acts like it is not getting the video signal from the PC. If it still does not work then you will have to open it up and troubleshoot it.
It may have dying power supply due to bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 11, 2010
How to set date in my sonata digital watch
Just hold the reset button until the seconds start blinking!!!!!
Then to change secon press sec/strt button or to changr hour,min or date just press mode !!!!!!!!!!!!!!!!!!!!!!
Jul 13, 2012 | Watches
When I booted up my PC 4 days ago, my Symcmaster 193P monitor started immediately blinking continuously and very fast; it did so on the POST screen and went on after booting in Windows too. It stopped and...
Yes i do agree with you there is no problem with a graphic card,and i suspected it to be a problem with the cable which is used for connecting but it was fine when you swapped the monitors however i would still suspect on the slot where the cable is connected,may be you should try samsung service center before you decide.
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
2000 Toyota Rav4, just purchased. Has a two button Toyota FOB for door locks, alarm and remote starter? . The vehicle has a OEM Toyota remote starter installed but I don't know what combination of buttons...
My ex girlfriend had a factory installed honda remote strt on her vehicle. It was activated by hitting the lock button two times in succession. Some vehicles use a combination of the lock-unlock buttons. try using some combinations on the remote, many "oem" remote starts are installed by aftermarket installers so who knows what they did as a start function, it could also have been changed by the previous owner.
Aug 23, 2009 | 2000 Toyota RAV4
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Jan 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Monitor takes up to and over an hour to boot up !
Sooner or later it will not work at all. Time to go shopping - not worth fixing. Go ebay for great prices on used/new units. eBayeBay
Sep 15, 2017 | Hanns.G Corporation JW-199DPB 19" LCD...
Samsung SyncMaster 931B 19" LCD Monitor Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
