Question about Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME
On the ldr equisite dishwasher air gap, where do you put the washers that come with it? there is a cloth washer and a shiny, thin metal washer that came with the air gap. i just installed the gap a few days ago, with metal washer on top of the sink under the air gap nut; it is already rusting; it looks like stainless steel or chrome,, so why is it rusting? i put the cloth washer under the sink. mike
    New Friend:
The metal washer belongs under the sink.
Posted on Jul 22, 2017
Dishwasher not draining
if your washer is installed correct your sink has an "air gap" that could need cleaned ( on sink top next to faucet theres a short stubby silver cap) under this is a plastic cap that unscrews (dont run washer with this off water will come out ) try pouring a bit of water down hole if it is blocked your air gap is plugged this will require a plumber to dissasemble it to clean it off
Feb 19, 2015 | Dishwashers
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
My Bosch shx46A05UC no longer will
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
Our Whirlpool washing machine stop draining the water. What seems to be the problem?
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Good Luck!!
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Viking dish washer won't drain
Try clearing the air gap (which is the seemingly pointless thing that is near your kitchen faucet.)
1.Take off the shiny metal cover, and you can sometimes twist off the plastic cap, or you may need to use needle nose pliers to push in the tabs that hold it in. You may or may not see debris in the tube that is in the air-gap.
2. Now what you need to do is take a clear glass and put it over the air-gap with part of the glass hanging over the edge of the sink, you may want to put a towel around the other side of the glass to keep the water from going all over the counter, turn the dishwasher off then on again and select "rinse and hold". If there is any thing in the line it will come out.
3.If not you may need to take out the filter in the bottom of the dishwasher and on the left hand side in the sump area there is a small, (usually yellow) cap that covers the drain motor impeller that can usually be pulled towards the center/right by hand, if not with needle nose pliers. You will need to vacuum out the water with a wet/dry vacuum or towels.
If none of this works, let me know and I will go over some more uncommon draining problems.
Dec 07, 2008 | Viking 24 in. Professional Series VUD141...
Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Oct 27, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Leaking when wash starts
If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Check if any of these is the problem..
    1)Drain hose is kinked or house drain is restricted.
    Straighten the drain hose to improve water flow to the drain.
    Standpipe is too high.
    Standpipe must not exceed 96 inches in height.
    Drain hose has been taped (or sealed) into the standpipe.
    Tape holding the hose in the standpipe should not form a complete seal. The standpipe needs air for proper draining. Remove some of the tape to make an air path.
    Drain hose fits too tightly in the standpipe.
    There must be an air gap between the drain hose and the standpipe for proper draining. The standpipe needs to be at least 1 1/4 inches in diameter.
    Oct 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
    Ldr Industries 520 1300C ADJUSTABLE SHOWER HEAD - CHROME Logo
    106 people viewed this question
    Top Ldr Industries Home Experts
    john h
    Tom Chichester
    Are you a Ldr Industries Home Expert? Answer questions, earn points and help others
