Question about Palm Treo 755p Smartphone
Pictures not being displayed treo 755P
I can't see pictures in the website or emails. I only see a red x on the top left corner.
thanks
    Problem Solver:
  • 8 Answers
From your web browser, press your menu button, then go to "Options", select "Preferences", select the "General" tab, at the bottom Un-Check the box next to "Don't download images!
Hope this helps,
Glenn
Posted on Jun 22, 2008
When you turn on Treo you get an error message 'update ROM Image?' If you select yes is displays ROM Image not found and then displays a screen with 8 multi-colored squares
"rom Image" is reffering to the operating system on the phone, this is common when rooting android phone but not sure on treo, check treo website for "rom update" may have to plug ur phone into your computer to doit. hope this helps
Oct 26, 2010 | Palm Treo 755p Smartphone
Unlock Palm Treo 755p
palm treo 755p doesnt have a sim card tray!
sorry
Mar 03, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
Loading Palm Treo 755p Software onto laptop with Windows Vista
Make sure it is a 32bit operating system on you laptop...if your operating system on your laptop is a 64bit it will not work. Check the Palm support website to see if they have a current download
Jan 06, 2009 | Palm Treo 755p Smartphone
I have same treo 755 problem, did you get it fixed?
I had the same problem, and here is how I fixed it. First, I hit the middle up/down key at the top as it was cycling between Access/Palm, and when it came to Palm, I turned it loose. This got it to go to the regular screen, but guess what....my phone would not work! So, I took it to the local Verizon dealer at Circuit City, and there I asked the guy if he would do a Hard Reset. He did, go the phone back up working again, but of course I lost EVERYTHING. Luckily, I had done a syn not too long before, and instead of telling the long story of what all happened there, I was able to get all the backed up info back onto my phone, and now everything is back to normal. This has happened to me twice (the first phone was replaced as defective, but it could have been fixed the same way). I love the Palm 755p, but be sure and sync as often as possible on your computer. It saves you from having to enter a ton of phone contacts back in manually!
Jul 16, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
Treo 755
yes go to preferences and buttons and change the email to messaging
Jan 31, 2008 | Palm Treo 755p Smartphone
Treo 755p
There is many answers to that but they require more information what do you have excess of saved to your phone. What is the information application that you want erased?
Sep 18, 2007 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
47 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
