Question about Sony XE-90MKII 9-Band Car Equalizer
I dont know where to get a power supply for this thing
Ii replaced all the parts in my percision analog power supply i dont know how tp reconect tbe wires can someone help me
I'm not sure what that is but I would probably go online to find the answer you will probably have to take it to a place where they know about these things or just DIY (do it yourself)online.
Apr 28, 2015 | Power Computers & Internet
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
I have a PS3 100 volts, is it posible to change the power supply t0 220v,
BEFORE READING THIS PLEASE NOTE THAT I DO NOT HAVE A PS3 AND I DON'T KNOW IF THIS WILL WORK. IT HAS WORKED FOR OTHER THINGS FOR ME BEFORE, BUT I CAN'T SAY FOR SURE THAT IT WILL WORK IN THIS CASE.
No, but you can get a 100v power supply and splice you ps3 power supply to it. if you dont know how to splice something, you simply cut both cords, strip the wires, and solder or twine the correct wires together. if the wires are insulated inside the shrink wrap (outer coating of rubber), that makes it even easier. just match the colors.
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
No power
Could be the power supply like you said and the most obvious things to check when its open is the small fuse on the power supply or any capacitors which are buldging which are faulty.
This is for lcd monitors which have a built in power supply or if you dont know they use the kettle type lead =].
Feb 11, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
Ok my dell that i have is a intel celeron d dimension 1100 with windows xp home on this is the prob with it i pluged it in with tha power supply and tha green light comes on but whe n u hit the power...
The power switch/button may have a polarity issue. Remove the power cable from the back of the PC, then swap the power switch connector on the motherboard 180 degrees (put the connector with the two different color wires back in the opposite way it was on).
Dec 02, 2008 | Dell (8N816) Motherboard
Playstation 3 power supply
if it does not turn on then its the power supply.. make sure you get a power supply matching your ps3.. the 60gb models have chrome like housing the 40gb have a dull grey color .. different wattage used means different supply is needed.. if you need more help let me know
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Power conversion
Dont do any thing with your printer power supply and just purchase Step-Down AC Transformer. Its input will be 220Volts AC and will out 110Volts AC. One thing important, read the printer power consumption watts and get proper one. Got the point buddy?
May 29, 2008 | HP LaserJet 1200 Printer
Doesnt start anymore
ok a couple things this sounds like
1 the dual power button on back of power supply needs to be triped
2 the power supply took a dump on you need to replace power supply
if your motherboard had crashed you would have had a meltdown in tower and you would have smelled it like burnt plastic
sometimes comps require a beefier power supply and most basic comps come with twiggy kind of power supplys
depends on how many toys you have in your system and how long its being ran
May 28, 2008 | Intel Desktop Board D845WN Motherboard
Motherboard Problem
let me know if you know how to use a multimeter
Dec 08, 2007 | IBM ThinkPad T30 2366 Notebook
Pioneer vsx 808 rds poweroff?
Could be lots of things, could be the tray not fully loading, or power supply problem...
Dec 03, 2007 | Pioneer DVR-520H DVD Recorder
Sony XE-90MKII 9-Band Car Equalizer Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
