Question about Vacuums
Vs 207 light blinks that's it worked once bought used
  • 2,299 Answers
I had same problem and the fix was simple. Over the summer the water level sensor stuck in the "empty" position so the unit thought it had no water. Remove the phillips screw holding the components in and clean them and reassemble. This solved my problem and took 30 seconds to complete
Posted on Nov 11, 2010
Dyson DC35 doesn't work. when I press power button, only green blinking light is showen.
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC35 is currently displaying a slow flashing light when you pull the trigger. In order to determine what's causing the issue, our experts would need to talk you through some simple diagnostic checks when you have your machine easily to hand.
When it's convenient for you, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we'll also be able to confirm whether this is covered under your Dyson warranty.
We'll look forward to speaking with you.
Jul 21, 2015 | Dyson DC35 Handheld Vacuum
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Black decker problem
Sounds like it could be a bad battery pack that's not accepting a charge.
Jul 14, 2014 | Vacuums
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Cleaning Solution
Most any brand name carpet cleaning solution will work. I like ZEP from the Home Depot. Nice fragrance, low foam and economical vs. Bissell, Hoover, other appliance brand names.
Jul 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
