Question about Whirlpool Washing Machines
Door warning light comes on will not wash had new door switch susan.tonks1@btinternet.com
  • 77 Answers
I had something simular the other day ...does the appliance start briefly then stop and the door light activates if this is the case it will probably be the motor failing.
Posted on Nov 11, 2010
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
DOOR
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
also...
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
The dome light will not come on when driver door opened. Door jamb switch is fine.
Have you tried a little squirt of wd40 or graphite in the door jam switch and then hand manipulate it a few times?
Feb 14, 2015 | Cars & Trucks
When I try and access my emails on btinternet.com, from iPad I get an error message that the server "mail.btinternet.co" is not responding. I have deleted the Account from the iPad, created it again a
Hi
Being a BTinternet customer myself, I am not surprised that you have a problem IF what you have put here is correct because the server you require is "mail.btinternet.com" NOT "mail.btinternet.co" as you state.
Cheers
Nov 29, 2014 | btinternet.com
The display has stopped working
Hi.
It appears that you may have a fault in the front display board.
If I had the product number (found normally inside the door) then I could give you a replacement cost.
If the fault is in this area then it will cost approximately £160.00
regards
Aardvark repairs
aardvark.repairs@btinternet.com
Nov 18, 2009 | Washing Machines
Rubber door seal problem
In my 13.5 years experience I have never experienced a door seal coming away from the drum!!!
If this was the case then you would have a major water leak!!!
Does the door seal look twisted at all?
Have a good look at the seal. Is there any black mold on the seal?
If the seal has come off then I would need to guide you through the refit process.
Please email me on: aardvark.repairs@btinternet.com and I will email you back my phone number
Regards
Aardvark Repairs
Nov 17, 2009 | Washing Machines
Interior light stays on and door warning lamp
some where along the edge of the door there is a push button switch that is deactivated when the door is shut, turns light of and turns door warning lamp off. either at bottom rear of door or up by the hinges.
Aug 25, 2009 | 2000 Ford Ranger SuperCab
Hotpoint first edition washing machine door will not open after completing its full cycle
hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
Apr 15, 2009 | Hotpoint First Edition WMA12 Front Load...
Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Interior lights problem
there is a switch that is activated when u open the door, it is called the courtesy light switch or the door ajar switch, u will need to test it for continuity, most likely it is defective.
Jan 24, 2009 | 2001 Volkswagen Golf
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
