Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Oil light keeps flashing, Check Oil but the oil gage says that it is full.
  • 297 Answers
The flashing comes on just before the 50 hour mark, then again every 50 hours. It has nothing to do with the actual oil in the engine. It is a reminder only to change the oil. It will then reset after the 50 hour intervals. You dont need to do anything to shut it off.
Hopr this helps
Posted on Nov 12, 2010
Red check Gage light on oil gage went all the way down.oil is full made a light nocking noise.still runs but makeing nocking noise.
Knocking noise is not a good sign. Could be the oil flow has been disrupted. Continued driving could damage the engine. Take it in for service immediately.
Apr 24, 2016 | Cars & Trucks
Check gage
Check what gauge? Is that your check engine light or is it a check oil light? A lot of times if you turn a corner fast your oil gauge may signal low oil. Check your oil make sure it is at the proper level.
Mar 11, 2016 | Cars & Trucks
Gauges going crazy
Euc? Do you mean ecu, the computer? Don't think so. Something in the cluster, maybe the little voltage regulator on the back of the cluster. But if the engine light is flashing, definitely have it scanned for trouble codes, first, to see why the light is on. The light may indicate a poor link or connection with the cluster.
Aug 13, 2013 | GMC Envoy Cars & Trucks
Oil light keeps flashing but i know the car does not need oil
Have you change the oil filter?
Are you using the correct oil?
Flush all the oil out, drain the oil res' , Change the oil filter and check oil Gage (usully 10-40w)
Jun 05, 2012 | Vauxhall Astra Cars & Trucks
Oil gage light is going on and oil was just changed
After truck has sat for an hour, check to make sure oil is full. At the add line is one quart low and enough to set off the light. After that you may have an oil pump or oil pressure sensor problem.
Mar 01, 2011 | 2002 Jeep Grand Cherokee
My oil light keeps flashing when i drive my 06 charger, even after i got a oil change, y is that???
Either low oil pressure or oil pressure monitor problem. You can screw a after market mechanical gage in to see what the real pressure is and go from there.
Feb 15, 2011 | 2006 Dodge Charger
The light of check gages turned on for a 1999 tahoe and dont know what does it mean exactly
I have a 1998 chevrolet k1500 check gauge light keeps comming on and off then the tack ans speedo dose not work and truck pulls out in 3rd gear
Mar 02, 2010 | Chevrolet Tahoe Cars & Trucks
After oil change, pressure gage drops to zero and check gages light comes on after running for five minutes. oil is still full though.
Remove, check and replace the Oil Pressure Sensor. It should be located adjacent to the Oil Filter.
Dec 28, 2009 | 1999 Jeep Grand Cherokee
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
1995 jetta oil light buzzer problem
You need to install an oil pressure gage. If the pressure is good then check the wiring to the sending unit. It could be a bad sending unit but don't replace it until you test the oil pressure. If you don't want to add the gage inside the car you could install it under the hood or use a manifold gage, it's mechanical so oil flows right to the gage instead of a sending unit, you don't leave it on the engine. Mechanics use them to test engines and transmissions. You can buy either at a auto parts store. If you have low oil pressure then either the pump is bad, the oil pump pick up screen is clogged, or the engine is worn out (bearings, valve guides, piston rings).
Feb 05, 2009 | 1984 Volkswagen Jetta
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
1,276 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
