Question about Ricoh Aficio 450 Copier
How to reset error E5 on nashua coprier - Ricoh Aficio 450 Copier
  • 21 Answers
Theres no e5 on aficio 450must be sc542/546 problem with heater try to reset code press yellow
button then 1 0 7 then press red button keep the red button held down 4 secounds then select
copy 1 turn copier off then switch back on
Posted on Nov 11, 2010
Unexpexted error occurred. resatart phone.
try to do factory reset by settings or hard reset *#7370# (this hard reset will delete all data so first make backup) and default code is 12345
Jun 28, 2012 | Nokia E5 3g Gps 5mp Wifi Qwerty Unlock...
How can i fix a SC- 546 error on my NASHUA Aficio 2018D all in one problem
You could try to reset the error, but it may come back. Here is the key sequence for resetting:
CLEAR MODES
7
STOP (hold down for three seconds)
You can then switch the machine off then back on. If the problem comes back, then you will need to have your fuser unit repaired.
Mar 13, 2011 | Office Equipment & Supplies
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Conon mp160 e5 error
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Apr 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
C62 error code - NASHUA 8112RE
Is this right out of the box?? If it is, make sure that you have removed all the SHIPPING SCREWS. Check for the one that holds the optical scanner. If this screw is left in the scanner will not move and cause error. ---should be on left side or under left side of optical pan. If all shipping screws are removed, do a once over and check to make sure that all shipping tape and paper are removed. Some companies use tape to hold parts in place.
Jan 03, 2009 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
362 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
