Question about Endless Summer gwt501a Open Flame Patio Heater
NEED TO KNOW WHERE TO GET A NEW PILOT ASSEMBLY FOR MY ENDLESS SUMMER HEATER MODEL 153100 PLEASE EMAIL ME AT JDICKINSON2@LIFESTAR-RESPONSE.NET
  • 4,472 Answers
Call 1-800-762-1142 to procure parts from the manufacturer.
Thanks,
lee
Posted on Jun 17, 2008
The pilot won't ignite. It's a table heater that worked perfectly one day and didn't the next. Help please.
Look for dust or contaminants inside the pilot safety device. Blow it out with shop air or flush it with rust buster. If yours is electronic look for contaminated flame sensing device. Clean it with emory cloth and rock on.
Nov 16, 2011 | Endless Summer 153100 Open Flame Patio...
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
When you light the pilot, then put on the burner, it will only burn for 20 - 30 seconds and the pilot light, burner and everything goes off. When you re-lite, the Pilot light will not stay on after you...
Either the thermocouple connection into the gas control valve is loose or the thermocouple needs replacing. Also check the burner and pilot assembly inside the screen area for dust, dirt and insect build up. A clogged pilot can mimic a faulty thermocouple.
Hope this helps you in troubleshooting and solving the problem.
Apr 23, 2011 | Endless Summer 153100 Open Flame Patio...
Can not start pilot light. where is it located?
The pilot light is at the top of the heater inside the mantle screen. You will need to disassemble the top of it, to access it.
Mar 12, 2011 | Endless Summer 153100 Open Flame Patio...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
The pilot light won't stay lit, sometimes it will stay lit and start the heater, but then it just turns off within 5- 10 seconds?
Probably the thermocouple is bad and needs to be replaced. I assume you have enough fuel? . Is this a new unti or is it a bit old?
Mar 29, 2010 | Endless Summer 153100 Open Flame Patio...
Need part # 56-01-127 pilot assembly
Call this # and order 1-800-762-1142. I hope this helps.
Dec 19, 2008 | Endless Summer 2009 Open Flame Patio...
Endless Summer Model 153110
try to clean flame sensor with wire brush
Apr 12, 2008 | Endless Summer 153100 Open Flame Patio...
Endless Summer gwt501a Open Flame Patio Heater Logo
136 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
