The fax is still not giving our faxes
I went to the manual and changed it to fax mode and had a co-worker send me a fax. well it worked, then we had had another fax ring in and it didnt print, whats up with that
  • 148 Answers
Make sure it is on auto answer also...
Posted on Jun 17, 2008
you need to change your mode key to fax only
Oct 26, 2009 | Brother Office Equipment & Supplies
Cannot receive fax - need to set up external TAD receive mode but gives error message "DR Mode in Use"
The machine should have a menu selection. Sometimes it takes patience and time to sit down and go through items to select.
Without having a manual to check, these menus should be available for one to make changes to the fax features.
Somewhere in the menu selection there should be a fax setup recieve and send mode. In that selection you should find the choice to make your changes.
If you do not have a manual, other than finding someone with a manual, this would be your best way to make the changes.
The vender might have the manual, if they do, it might be for a fee.
Good luck
Oct 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Fax machine sending but not receiving --help me!!
Check the settings and see if it went into "memory" mode. They may call it somthing else in the menu so check the manual if you have it.
Mar 23, 2009 | HP 1040 Plain Paper Inkjet Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Canon Laser Class 7000 H12013 - need user manual - 'received in memory' on display
we have this machine! all you have to do is hit the green button and they will print out!
Jan 15, 2009 | Office Equipment & Supplies
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Canon g3 super fax machine
My co-worker knew how to do it and she took care of it for me. I can't give details because she took care of it for the office.
Sep 17, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Sending an International Fax
definitely there is a setting which should be changed in order to send fax
Jun 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
32 people viewed this question
