Question about Lexmark X4270 All-In-One InkJet Printer
Printer will not function. Power light on, fax light on. Won't turn off with buttons. Disconnected power and usb and reconnected, still nothing. Can it be set back to factory specs?
    Genius:
  • 1,087 Answers
Refer to this article How to Restore the Factory Defaults on the Lexmark X4250/X4270 for instructions on how to reset the printer to its factory settings. If the printer still won't turn off using the power button, unplug the power adapter from the printer. The power adapter is the rectangular black brick behind the printer where the power cord plugs is plugged in. Replug after 30 seconds. That should give enough time for the printer to refresh itself. Thanks.
Posted on Nov 11, 2010
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
I installed new cartridges (Lexmark brank both black and color) and my printer won't work now.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 All-in-One InkJet Printer
Computer won't detect printer
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
Lexmark X4550 Scanner not working
  4. Reboot computer.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Jan 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Reset power light comes on
    connect the printer directly to wall outlet then disconnect the power chord from the back of the printer press the on button on the printer for 10 times reconnect the power chord back to the printer.
    try printing
    Oct 10, 2009 | HP OfficeJet 6310 All-in-One Printer...
    HP Photosmart C5180 All-in-one error Oxc18a0301 I replaced 2 ink cat with proper ink. Now I get error oxc18a0301 I have the same problem with the HP C7180... I try to do unplug, move the cartridge,...
    I tried all of the above, but nothing worked. The error message continued to appear as soon as I would turn on the printer and blocked whatever function. I had it back in the shop to service it, but they just told me not to spend any money on it and buy a new one. So did HP itself when I contacted them.
    I finally ran accross this, which took of the errore message and now actually the printer is working like before.
    I had the USB disconnected, the power cord disconnected as well and all the cartridges taken our, just as written in the instructions above. But then turning on the printer again, I hold down the OK and HELP button. And that did the trick for me: My C5180 would turn on and then switch itself of after a while. I then stopped to hold down the buttons and turned it on normally (still no USB connected) It did all the setup (language, country, ecc.) and then finally told me that the cartridges were missing. I reinstalled them and turned back to normal.
    Hope it'll be of help for some of the many desperate HP users.
    Jun 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
    HP C6180 all in one
    Have an HP C6180 that would not turn on, no power. Unplugged and replugged the unit in the back - no fix. Unplugged the unit at the wall socket, reconnected and I thought I heard a faint click in the power supply. Hit the on button and the C6180 powered up - no issues. Without knowing for sure, possibly the power supply has some type of surge arrest safety switch.
    Aug 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Machine sleeping even when re-powered on
    Hi try changing the fuse in the plug first. Once you have done this then power in and open the cartridge cover and press the cartridge button. If the cartridge moves then the LCD has blown and will need replacing if nothing happens then unfortunately the power supply board has blown then replacing the whole machine is the cheapest option.
    Thanks J
    Nov 22, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
    Lexmark X4270 All-In-One InkJet Printer Logo
    60 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
