Question about HP DeskJet 697c InkJet Printer
Paper intake problems
My dad has an old HP 679c that prints just fine but the wheels that should take the paper into the printer don't grab the paper. The wheels seem dry and may not be soft enough or tacky enough to pull the paper in. What can we do to solve the problem. Is there something to soften the rubber wheels? The printer works fine if we manually feed/push the paper into the printer.
Thanks.
  • HP Master
  • 5,568 Answers
Once upon a time . . .
This problem was quite common and HP even designed a fixture (mine is history, along with printer repair in general) that was placed in the paper intake and simple software caused the printer to grind away for several minutes slightly removing the dried surface rubber.
The rubber compound doesn't really like alcohol (it tends to work briefly then get even worse) or most other solvents.
If you have a copier repair shop nearby, you might try begging a little rubber restorer from them since this problem is common to some copiers too.
The treatment will remove some rubber but leaves a tacky residue that is pretty durable.
When the printhead drive belt fails, replace the printer as the belts run close to $60 US from an aftermarket supplier; HP discontinued them about a decade ago.
Posted on Jun 17, 2008
Paper misfeeding on one side but printer keeps printing with no paper
Look for any foriegn objects or old torn paper from an earlier jam. Something is either obstructing or mis-guiding the paper. If nothing is found, use a can of compressed air to blow thr paper intake area out, then test print again.
If still not solved, use a cottom swan soaked in alcohol to scrub clean the rubber paper pickup roller. Over time it gets slick from paper dust and the paper will notget grabbed evenly, causing it to skew as it's pulled in.
Jul 26, 2011 | Lexmark X2470 All-In-One InkJet Printer
I am trying to print some 'buisines cards off my laptop, the printer will not accept the glossy paper (255g/m2) nor the glossy (194g/m2) the printer does not 'pull' these sheets through, is there a means...
Hi,try placing a sheet of fine sandpaper in the paper tray. As soon as it
starts to feed grab it so that it polishes the glaze off the rubber
feed rollers. Let us know if this solves the problem.
Thanks for using fixya.......
Dec 02, 2010 | HP DeskJet 1220c InkJet Printer
Printer feed will just not grab paper
Rollers need replacing. They are supposed to have tread like tires, if not, Replace.
Apr 06, 2010 | Canon Office Equipment & Supplies
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
I am having difficulty loading paper into the printer. When printing, the printer grabs the paper and tries to load crooked and then fails to load.
This could be for a number of reasons. Are you making sure that the guides are reasonably tight so that the paper cannot slew? Is the paper damp, or old (same thing)? Some papers, particularly cheaper types, have a coating on them which is powdery, which prevents the take-up wheels grabbing properly. Been there, done that.
Jun 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Laserjet Printer
if it seems like it wants to take the paper in on the first print but don't and then gives you the error message , then the paper feeder will need to be cleaned ( rubber grabing wheels)
if the error message comes on before it trys to grab paper , then there is an internal problem with the printer
if this helps you then please give a fixya rating and i will tell you how to clean the paper feeder rollers
electech
Nov 07, 2008 | HP LaserJet 1320 Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP psc 1210xi paper jam
I found out my all-in-one was not supported since it's old---but works well. Since the machine doesn't open up, I just gently tugged on the paper from the longest end until it came free. It does not seem to have suffered any ill effects and prints just fine, now.
Connie
Jul 23, 2008 | HP Office Equipment & Supplies
Printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP DeskJet 697c InkJet Printer Logo
164 people viewed this question
Ben Johnson
