Question about Canon PIXMA MP830 All-In-One InkJet Printer
I get a long line of black ink on the reverse of my printouts copy or from computer print.
  • jamescaulde8 Nov 17, 2010
    Thank you for the suggestion. Now for even a dumber question: How do I get to the rollers?
    Genius:
  • 1,044 Answers
Please clean all the rollers with a blowers. What happens is that external material like hair, dust particle or even a small grain get entangled in the roller which we are not able to see in the normal maintenance. These absorb ink when the printhead/cartridge is moving, thus giving dirty lines/blots on the print outs. I had the same problem with Canon i 80 printer. It was a small piece of hair.
Posted on Nov 12, 2010
  • Adarsh Saroj Nov 17, 2010
    Please the remove the paper tray and open the top cover when you replace the cartridges.
    You will see the rollers. Clean the rollers with a slightly damp cloth. Blow the compressed air to remove any outside object/felt threads/hairs etc.
Brother lc 75
The choice should be in the "printer settings" that you would display on your computer screen. This is where you change the size of paper, quality of print, number of copies to print. Sometimes there is a choice labeled "grayscale" which gives a little bit of a better looking printout out instead of all black.
Jan 31, 2014 | Office Equipment & Supplies
When I print black and white photo prints, there is a blue hazy line across the photo, how do i get rid of this?
Sounds like a dirty print head. Please click on the below link and it will take you to the HP support page for this problem with step by step instructions on how to solve this.
Thanks.
HP Photosmart C3100 - Lines or Missing Ink on Printout
Dec 17, 2012 | HP Photosmart C3100 series
We just installed a new black cartridge in Dell printer A940 and it will not print black or copy what is going on
Black printer ink in Dell Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | Dell Inkjet 720 Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
My HP Photosmart 8250 Inkjet printer is not printing black ink. If I let it sit for a while and only print 1 copy it will print a pretty good copy. Additional copies are almost blank but will have color...
try to reinstall the printer driver software. you can download the latest printer driver software from yout printer manufacturer's web site then restart the computer and printer.
Jun 11, 2010 | HP Photosmart 8250 InkJet Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Black lines printing through words on printer.
Have you tried printing a Nozzle Check using only the printer - this eliminates problems caused by the computer. Have a look at the online guide at:
http://support.epson-europe.com/onlineguides/en/sc60/index.htm
Choose Maintenance - Checking the Print Head Nozzles - Using the Control Panel Buttons, and follow the instructions to produce a nozzle check printout.
Does this produce your lines? If not - the problem lies with your computer. If it does, you need to have your printer checked out by a technician since it appears you have some sort of ink leak from your print head..
Mar 18, 2009 | Epson Stylus C60 InkJet Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Photosmart C6180 will not print in black ink. Have all HP genuine cartridges, although I have used cheaper imitations in the past. Have tried aligning print heads, cleaning, master reset (# & 6...
do not print the printout from the pc.tyr to print a test copy by pressing the menu button on the printer and in that select the option print a self test.then press OK.if the test copy from printer gives proper black colour then its the print setting problem in the pc.just adjust that setting.but if the test page does not print any black line or object that means the cartridge is out of ink and needs replacement.
Nov 29, 2008 | HP Office Equipment & Supplies
Copier leaves an ink line down the front of the document when fed through the unit.
Hi there if the line appears when you use the document feeder then there is usually either Correction fluid or pen ink on the small piece of glass to the left of the main glass when you open the lid you can easily clean this by wiping the glass with windowlene or some sort of glass cleaner and this will get rid of your problem.
If the line appears when coping from the glass then the printout from the computer will be the same and that usually means that the print heads need cleaning. Take them out and using a soft cloth wipe the print heads clean from any dried toner.
Hope this help you
Thanks J
Jan 13, 2008 | HP 5510 4-in-one Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
32 people viewed this question
Clive
Clive
old marine
old marine
