Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Where is the fuel filter located on a Husky 141?
  • 4,066 Answers
Look inside the fuel tank. That's where most of them are. On the end of the fuel line in the tank.
Posted on Nov 11, 2010
Husqvarna 141 starts with choke and then cuts out
If the chainsaw has been used recently i would say It sounds like the screen filter inside the carburetor is dirty item # 507432582 or the metering diaphragm is dried out item # 530035165. Also check that the fuel lines are in good shape. If that doesn't solve your problem you should do a pressure and vacuum test to check the seals and gaskets.
Feb 01, 2014 | Husqvarna Garden
Need to know which champion spark plugs are right for my husky 141?
Here are all the spark plugs you can use:
Champion CJ7Y
NGK BPM7A
Mega-Fire SE-Y7C
Denso W22MP-U
BOSCH WS7F
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do i take the oil tank off a 41 cc husky chain saw
I guess we are talking about the Husqvarna 41/141, start by removing the guide bar and chain, remove top cover, disconnect and remove the throttle wire, remove the fuel hose from the carb, use a 4mm allen key and remove the front anti vibration rubber screw ( drive side, bottom front r/h, holding the alloy chain catcher ) now remove the top anti vibration rubber screw with a cross head screw driver ( top l/h holding an orange plate ) now remove the four screws securing the starter cover, two screws are into the plastic crankcase, and two are into the anti vibration rubbers, the fuel tank should now pull out from the bottom of the saw withe top handle still connected, make sure the fuel hose feeds out of the crankcase as you pull the tank away.
Feb 10, 2011 | Garden
Hi there, I got the Husky 240e, with only ~4h of running. my problem is that the chainsaw starts smoothly but when pressing the throttle it is suffocates and turned off. When gently squeezing the...
The symptoms indicate lean running, so check the fuel filter for plugging and the fuel lines for decay or other damage. Husky seems be having troubles with our ethanol treated fuel and may require some warranty attention. We have a year old 435 Husky that would not start after about 3 days of excellent running--warranty replaced the carburetor which seems to have us working well now. Good luck!
Aug 09, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
Chain saw no start
It needs spark, fuel and compression to run, which is missing?
Lets start with spark. Replace the plug (very inexpensive and great insurance), then do this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Before we get to fuel please download and follow the start procedure in your Operator's Manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I own a Husky 359 that 1 time I forgot to set the fast idle (close then open choke). It was near impossible to start. I have missed the initial attempt to fire and flooded it too, again almost impossible to start.
If it has spark and the start procedure fails, put a teaspoon of fuel mix in the carburetor throat, open the choke, and pull. Does it fire and attempt to start? Yes it probably has a fuel delivery problem. Please repost with what you did and we will continue. HTH
Lou
IMO regardless of what your manual says ( yours probably 50:1) all 2-cycle engines should be operated on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle engine oil). Once adjusted for this mix they start easier, pollute a bunch less, and do not foul out plugs, cylinders, or mufflers. Run lean conditions are most often caused by dirty air filters, air leaks not detected by the operator, or failing to add any oil to the fuel in the tank. Using a 32:1 mix prevents none of these occurring! I use a Pioneer chainsaw I purchased new early 1980 with a 50:1 mix.
Jan 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Where is the fuel filter on a 1997 husky 55?
The fuel filter is in the fuel tank. Use a piece of wire with a small hook on it to fish it out of the fuel tank.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Fuel filter replacemfnt on husky chainsaw model 345
the feul filter will be in the tank disconnect feul line from carb and access through filler cap you will need a pair of long nose pliers remove through the tank
Apr 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Fuel filter nipple broke
get some proof in writing from the retailer noting the issue for future ref.
Feb 03, 2009 | 2008 Husqvarna TE 450
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
77 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
