Question about Eagle 271w-box Switch 15 Amp 120-277 Volt Toggle
Eagle switch (on/off with a light.I want to install it. it has 2 dark screws on one side, +line+. And alight shiney colored screw at one end, and a brass screw at the other end whitch says cu wire only. and a green ground in the center. in the wall i have a black and white wire. HELP PLEASE
    Novelist:
  • 107 Answers
The Eagle 271 is designed to switch two, separate circuits. If you only have a black & a white wire in the wall, then it sounds like you only have one switching circuit in there.
You could use the device you have if you want. Connected the black wire to one of the dark screws, and the white wire to either the brass or the shiny screw (just pick one). This will make one light switch work, and the other light switch will be solely for decoration.
(NOTE: I AM ASSUMING THAT THIS IS REPLACING AN EXISTING SWITCH, IF THIS BOX PREVIOUSLY HAD A RECEPTACLE IN IT, THAT WHITE WIRE WILL BE A NEUTRAL AND WILL CAUSE THE BREAKER TO TRIP IF HOOKED UP TO A SWITCH).
If you used to be able to switch two, separate circuits from this switch box, and you only see the black & white wire, then I hate to tell you, it sounds like you lost a wire in the wall.
Posted on Nov 11, 2010
Staircase wiring circuit diagram for 2 way switch
Copy following link for wiring 3-way switches (where 2 switches control same lights)
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plug green ground screw)
Two screws are 1 color usually brass, and other screw is different color usually dark.
The dark screw is common screw.
There are two basic wiring diagrams: Line-side/Load-side with neutral wire. And Line-side/Load-side without neutral wire.
Open link above and scroll down to see both wiring diagrams.
Nov 04, 2012 | Prime 10 Amp Circuit Breaker
I have a new combination switch ; I want to control two lamps from one switch i connected the main lines the white one from brass upper and the other from black screw and went I turn on the switch the...
The white wires from the two light fixtures get connected to the white wire from your power supply.
Then the black from your power supply goes to the gold colored screw on the switch. Lastly, the two black wires going to your light fixtures get twisted together with a third jumper wire. The other end of the jumper goes on the silver screw on the new switch.
Dec 21, 2010 | Leviton 15a 120v Sp Switch
I think I have a Leviton double pole dimmer switch. It used to operate track lighting along with an on/off light switch in the same room (different entrance). I replaced the track lighting with a fan...
You mention a dimmer and a 2nd on-off switch.
You purchased a 'double pole' switch which I believe is a 3-way switch.
3-way switch has 3 screws (plus ground screw which will not be mentioned further)
3 screws on 3-way switch = one is dark colored, and 2 are brass colored.
You can guess. There are only 3 wires and you can keep trying different combination until both switches work. Do not change wiring on 2nd switch and sooner or later the right combination will appear.
On the other hand, electricians test wires using ordinary tester, before connecting anything.
If you want to test, it takes 3 ez steps.
Here's what I would do.
1) Look at wiring on 2nd switch.
Notice switch has 1 dark screw and 2 brass screws.
If you can identify the two wires on the brass colored screws, these are the 'travelers' and same two wires connect to brass colored screws on new switch. And then last wire connects to dark colored screw.
2) You have noted the wires carefully on dimmer, so remove dimmer, and separate wires for testing.
2nd switch is moved to down position.
We are NOT going to test wires on 2nd switch.
We are just testing wires at old dimmer.
Turn on power.
Power is on.
2nd switch is in down position.
Test each wire to bare ground wire.
One and only one wire will light up the tester.
Mark this wire.
3) Change 2nd switch, and move 2nd switch to up position.
Test each wire again to bare ground wire.
Again only one wire will light up tester.
Mark this wire.
If same wire lights up tester each time, then this is the Hot wire and it connects to new switch dark screw. And the other two wires go to brass colored screws.
If a different wire lights up each time, then these two wires are 'travellers' and they connect to each brass colored screw. And the last wire connects to dark colored screw.
Dec 16, 2010 | Electrical Supplies
I would like to use the 1301 switch but my house circuit has 2 black wires and 1 red wire which terminals do I connect the wires to on the switch?
I don't know the copper-brand 1301 switch
Internet photos of the 1301 show that it has two screw terminals, and a green ground screw
Switch with 2 screws is a single-pole switch. (plug green ground screw)
Sounds like you are replacing 3-way switch with 3 screws. (plus green ground screw)
3-way switches control hallway lights, with switch at each end of hallway.
I think you need to buy a 3-way switch.
How to wire 3-way switch:
Bare ground always goes to green screw
The key is the dark-colored screw.
Old switch has dark-colored screw >> mark this wire.
Attach this wire to dark-colored screw on new switch.
Other two wires go to either screw.
Nov 19, 2010 | Cooper Wiring Devices "COOPER WIRING"...
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Wiring instructions for a two switch
If I understand correctly, you have a dual switch with one switch stacked above the other.
If this is not correct, add a comment and I will help further.
On each side of the switch are screws with different colors.
The brass screws show in photo above.
Sometimes these screws are dark-colored.
The brass screws are connected by a brass plate so both screws are the same thing.
Your black hot wire from breaker goes to the brass screws.
On the other side of the switch are two independent silver-colored screws.
If the screws on other side of switch are dark-colored, then the screws on opposite side are brass and not silver colored.
Your black wires going to Load (fan, light, motor) go to each of these screws.
Each switch receives the same power source through the brass-colored screws on one side of switch, but on the other side of the switch, each wire is independent as each switch controls a different Load.
Nov 04, 2010 | Cooper Lighting Lighted Switch
Need a wiring schenatic for 66v
I answer questions for free.
I know electrical wiring.
I have an image of the 66V, but it does not show the screws or color of screws.
I cannot find a manual.
SO, if you can 'add a comment' to this post and tell me the color of screws on each side of switch, I can tell you with 100% certainty where your wires go.
Otherwise I will shoot wild and see if I can hit the target.
1) One side of the switch has dark-colored screws and the other side has brass screws. The Hot black wire from breaker attaches to the dark-colored screws. The wires going to Load (fan, light) attach to 3 brass screws.
2) One side of the switch has brass-colored screws and the other side has silver colored screws. The Hot black wire from breaker attaches to brass screws. The wires going to Load attach to 3 silver screws.
Oct 30, 2010 | Broan-NuTone FAN CONTROL SWITCH
I have a single pole lighted switch with no wiring diagram. it has two screws on one side and three push connection holes, two marked common the other not marked. how do i install it properly?
I hesitate to answer question because the color of the screws is not identified. The holes are not identified which color screw they are next to. You can fill in these blanks when answering if the following information is not complete.
First of all, the green screw goes to bare ground wire and isn't discussed further
Usually a single pole switch has 2 brass-colored screws.
This tells you the wires from old single pole switch can connect to either screw.
Normally the quick-connect holes are located next to a screw >> that screw and the hole are connected. Sometimes there are two holes next to a screw >> and the same rule applies that holes are connected to screws they are next to.
If your switch has two screws and the colors are brass and silver, then that tells you something else.
It says that black-hot-wire-from-breaker connects to brass screw.
And wire-going-to-load (fan, light, motor) connects to silver screw.
If you do not know which wire is which, connect wires, if device doesn't work, then reverse the wires.
Again the quick-connect holes are located next to screw they are connected to.
If your switch has threes screws, then that switch has 2 brass screws and 1 dark screw.
You can wire this device as a single pole by connecting wires to dark screw and either brass screw
Oct 25, 2010 | Cooper Lighting Lighted Switch
Hi I have a 691 and want to outlet on all the time and the switch to control a light. Your diagram show black wires on one side and the white wires on the other side. Shouldn't a black wire be on one of...
If your switch is wired internally so the switch automatically controls the plug, then there is not a way to re-wire the insides of that device.
Look at the screws on your device.
If switch automatically controls the plug, there are probably gold-colored screws on one side of device and silver-colored screws on other side of device.
The blacks connect to gold, the whites to silver
If this is how your device looks, then the switch cannot control a light, so buy a device that looks like the one described next:
If the plug and switch can be wired separately, then the screws are different colors
1) On one side are dark-colored screws. The Hot wire from breaker box always connects to dark-colored screw.
2) On the other side of the device are 1 gold-colored screw and 1 silver-colored screw
- The white wire connects to silver screw and this will complete the circuit to the plug
- The wire going to your Load (light, fan motor) connects to gold-colored screw, and this will let the switch control power to the Load
You can buy a simple continuity tester and check your wiring devices before purchase:
Continuity tester is used when power is turned off.
It has a battery
When you youch alligator clip to the tester point on end of tester, a light comes on.
When light comes on, that tells you the circuit is complete
For testing switches and plugs, you touch the pointer on one screw terminal, you touch the clip to another screw terminal ... then flip the switch on the electrical device to see which screw terminals cause the tester light to come on
If light comes on, then the circuit has 'continuity'
Continuity tester can be used on all sorts of small electrical devices, including troubleshooting electric water heater >>> and that's a fun project for next week.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 18, 2010 | Pass & Seymour #691 15A Brown...
Rca hd61lpw165 color wheel replace
Remove speaker grill at bottom of set. Remove screen by taking out all the screws from the back of the rim of the screen. Two ribbon cables from the front controls need to be unplugged to set the screen to one side. Remove two screws holding the light engine shroud in place. Side it toward the front and lift out of the way. The color wheel housing as only two screws holding it down. There are two wires coming from the color wheel housing. One has three wires with a white plug on the end that plugs into the left end of the light engine's metal box. Next to the plug is a ribbon cable that is slid into its socket. You will notice two shiney philips screws holding down the color wheel housing. Remove them and the color wheel housing can be lifted out. Unplug the two wires going to the light engine.
May 01, 2008 | Televison & Video
Eagle 271w-box Switch 15 Amp 120-277 Volt Toggle Logo
164 people viewed this question
Top Eagle Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Eagle Electrical Supply Expert? Answer questions, earn points and help others
