Question about D-Link DI-624M Router (DI624MRE)
I have a Dlink routerand am able to connenct tothe internet but cannot access the 192.168.1.1 to make sure it is set up correctly. It dropoff everytime that I shut down and then have to set up broadband again. When I go to cmd ipconfig /all it does not show the default gateway. I previously had it working correctly and had to recover my pc since then tried to set it up with the cd but would not copletely install and configure. How do I take it off completely to reinstall.
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still unable to access with above ip then press RESET button for 10 seconds then all settings defaults then you can access it. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 11, 2010
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Why does my phone keep sayin set network connenctions
You need to call your service provider so they can set it up and activate your network connection.
Sep 14, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
After using wireless routerand having watch more than 3 netflix movies, i now can not reconnect to netflix or any internet channel on my wii.. I can still play games on wii but not go on line,,will not...
First thing to try is to set up the wireles connection again. Just like you did the first time, but use the "Connection 2" or 'connection 3' option. Let the wii search for access points and pick yours. If it can't find any access point then you know the wii is defective. If it finds access points hopefully yours is on the list. If not then maybe your router is at fault. (Wii Options->wii settings->internet->connection settings->)
Apr 19, 2011 | Nintendo Wii Console
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I have a DLink DIR-300 router and it perfectly functions and connects to internet. When I use my laptop, i have an uncommon problem. The laptop do connect to internet as normal and usual, but when i open...
log in and put in password.
set up router to automatically assign IP addresses and enable DHCP.
make sure your computer is set up to auto detect proxy settings when connecting to the internet.
Nov 26, 2009 | D-Link (DI-711) Router
D Link model 2310
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Nov 07, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
My new d-linkdraft n
how far away is the laptop from the router? what is the laptop using to connect to the router? wifi? usb wireless device? etc
Mar 08, 2008 | Computers & Internet
D-Link DI-624M Router (DI624MRE) Logo
60 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
