Question about HP Color LaserJet 3500 Printer
I've installed the laserjet cm3530 mfp in 5 of my 7 lan computers with no problems, but i couldn't do it in 2 of them. I used network installation with a fixed ip. and in those 5 pcs also installed de scaning assistant with no problems at all. why i couldn't install the printer in the other 2 pcs? The main setup window appears empty, no buttons, no explanation, , nothing but the green and grey color areas of the background, te landscape picture and nothing else. why is this happening? those 2 pcs having win7 ultimate OS.
  • 68 Answers
SOURCE: I would like to network
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Posted on Dec 04, 2008
manojro
  • 495 Answers
SOURCE: HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Posted on Feb 12, 2009
  • 489 Answers
SOURCE: Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Posted on Apr 23, 2009
YourZEN
  • 820 Answers
SOURCE: how do I install a hp laserjet cm 1312nfi MFP
There's Windows 7 support for the CM1312 series, see next site:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=3562006&taskId=135&prodTypeId=18972&prodSeriesId=3558902&lang=en&cc=uk
Pay attention to downloading and installing the matching bit-version (32 or 64) for your system.
Posted on Nov 03, 2009
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
My HP LaserJet M1120 MFP will not print if the network cable is plugged in
Mar 15, 2013 | HP LaserJet M1120 MFP All-In-One Printer
30.01.08 error on HP color laserjet cm3530
You're not real specific about the conditions surrounding this error message, so please have a look at this link to begin with. Then see here, with an enclosed link to contact the HP customer support system, should you wish to do so. Make sure you have the most updated drivers and firmware available for your printer, by checking the available downloads here. Here are some articles that will help you to check which firmware version you're currently running.
If, after ensuring that you are running the latest firmware, and manually power cyclying the machine and computer at least twice, you continue to have issues, this article may pertain and could be of help.
If that doesn't work, please consult this list of error conditions and follow the instructions that apply in your situation.
Otherwise, I suggest you contact HP directly using the link above.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2011 | HP COLOR LASERJET CM3530FS UP TO 31/30PPM...
Can we share HP LaserJet M1005 MFP printer through other computers
For your information, your printer model is not a network printer. So you can not use it individually from other computer in network. But you can share it in LAN. In that case you can use it through the computer where the printer attached directly & you have to make the PC turn on to use the printer.
To share the printer in LAN, go to the printers and faxes wizard in control panel. Right click on the printer and go to the sharing option. In this properties select share the printer option and click on OK tab.
Jul 13, 2011 | HP LaserJet M1005 Printer
HP 2727nf MFP software cannot be install through network
Are you installing SOFTWARE over network (i.e. from remote server) or you're installing your MFP over network? The latest means that you're installing software on your machine from CD/DVD/Image/etc and trying to connect to your MFP over network.
May 06, 2010 | HP Laserjet M2727nf Multifunction Printer
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Wireless lan for Acer Aspire 5101AWLMi
what operating system you using? xp or vista? home? premium? basic? at any rate use this link to select your unit and use the operating system drop down menu to locate the software that is loaded on the computer. from there select the correct driver. Make sure you select the Lan Driver first. Load that. THen select either the atheros or broadcom driver. if you install both it will be fine. the machine will only install the correct one to the device. good luck!
Ruben
Aug 27, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
HP Color LaserJet 3500 Printer Logo
79 people viewed this question
Clive
Clive
