Question about Cozy Enclosed Front Console Heater 20,000 btuh Propane
Have a Cozy 35,000 BTUH vented closed front heater with bad gas valve. Need to remove manifold from the valve. Is the valve a right or left hand thread.
  • 59 Answers
On back of unit remove the 2 screws holding down the gas valve, remove wires and pilot tubing from valve, open side access door and you will see a brass nut turn counter clockwise and remove manifold and valve out the back of unit then unscrew the valve from manifold.
Posted on Nov 24, 2010
The pilot will light, hen you turn the thermastat up it sucks out the pilot
Probable causes: bad gas valve, low gas pressure, restriction in venting, lack of combustion air.
Jan 18, 2011 | Cozy Enclosed Front Console Heater 70,000...
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
if you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Oct 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
I installed a new Cozy heater and it smokes while running.What's wrong?
If it is brand new they will often make some smoke on start up. Run for 10-15 min. and it should clear up.
Nov 12, 2009 | Cozy Enclosed Front Console Heater 35,000...
Heater turned up all the way won't heat the house
The temperature sensor that tells the unit to come on could be too close to the unit...smetimes they are loose and not in their correct location....the Thermostatic control itself can be loose or just older...out of calibration or just getting defective....sometimes you can adjust the knob and recalibrate it yourself by moving it slightly on way or the other ...I would lean toward getting older and the cntrol is getting weaker....or as I said the thermostat sensor is too close....beware though...too far away can make it run too long and get too hot could then cause a fire...always watch clearance to combustibles etc and make sure the sensor is where it's supposed to be...
Oct 31, 2009 | Cozy Enclosed Front Console Heater 70,000...
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
Every time the thermostat tries to switch the heater on, the pilot light goes out. Cozy natural gas mod # CDV 335A
remove the thermostat wires from the gas valve and put a wire accross the outer terminals if unit starts up the stat or stat wire is bad.
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Pilot light has no gas coming out, verified gas going into gas valve, but no gas coming out when pilot light button depressed.
Pilot orifice may be clogged. Remove pilot tube and orifice. Blow out orifice with compressed air only and reassemble. Also, control valve may be bad.
Sep 30, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heating & Cooling Logo
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
