After refillig the cartarage their is an error toner emtry how can i remove this problem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Brand, model !!!
Posted on Nov 11, 2010
Help with toner reset problem on OKI B4600. After refillig cartridge, on display apears "Tonner Empty - Replace cartridge"
Go to the maintenance part of the printers program and clean the heads is the job to perform. The run a test page for alignment. It will adjust back correctly showing you have ink
Feb 26, 2011 | OKI B4600 Printer
Replaced black cartarage with brand new one and it says incompatible ink cartarage
remove it and clean its contact leads and put it back firmly till a click is heard.
Jan 05, 2011 | HP C4680 All-In-One Inkjet Printer
Xerox Document Center 440 replace cartarage every 4 coppies
just Check The Wiring of dc bord
in back side of a printer.
Dec 28, 2009 | Xerox Document Centre 265ST Printer
I have a Samsung ML-2010. I refilled the cartarage once and it worked great. I have refilled it a second time but now the print is very light. I have vibrated the cartarage to ensure that the toner was...
hi this is kamal...
just purchase your printer catridge coz ur catridge is not working properly.. so u need to change pls
and let me know this information was good or not
best regards
kamal singh
Oct 08, 2009 | Samsung ML-2240 Laser Printer
The toner light of HL 2140 will not go off. even if i turn the printer on/ off and wait for a few minutes. i've also move the green thing back and forth a hundred times and still the same. Please help!
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Sep 05, 2009 | Brother HL 2140 Laser Printer
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Jul 09, 2009 | Brother HL 2140 Laser Printer
No 27 black refillig mathod
check here
http://inkfilling.net/instructions-on-how-to-refill-hp-27-c8727ae-.html
Jun 10, 2009 | HP DeskJet F380 All-In-One Printer
Wont emtry
can you hear the motor spinning.
May 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Removal of cartarage of hp psc1410 all-in-one inkjet printer
Step1: Make sure the HP is on and paper is loaded in the tray.
Step2: Gently lower the print carriage access door at the front of the unit. Do not force it.
Step3: Press down on the print cartridge gently to release it. Pull it towards you and remove.
Step4: Gently clean the cartridge with a slightly moist paper towel and then pat dry
Step5: Slide the print cartridge into the empty slot, and gently push forward until it clicks into place. If it does not click, do not force it. Remove it, and try again.
Step6:
Close the print carriage access door. An alignment sheet will print to make sure everything is lining up.
Hope this helps & happy holidays!
-TJ
Dec 15, 2008 | HP PSC 1410 All-In-One InkJet Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
jasbo
jasbo
