Question about Kitchen Ranges
I have a late 90's Whirlpool stovetop that I had to clean.Now it does'nt ignite.?????.
  • janis bettencourt Nov 11, 2010
    stove top. ignitors no oven eletric ignitors
  • 2,299 Answers
On the burner there is a small hole in the part that fits around the ignitor. Make sure that the little small hole is clear.
Posted on Nov 12, 2010
  • 19,396 Answers
Hi.
The high temperatures generated in the self cleaning process can easily damage oven internal parts. Parts that get frequently damaged are the door latch, the temperature sensor, and the wiring to oven electronic control.
Before testing, ensure that the system is not simply locked because of incorrect settings (eg. self cleaning cycle not complete). Try first tripping the circuit breaker to cut off power for a couple of minutes, and try restarting the self cleaning cycle. Depending on the model you may also need to hold down the oven knob or perform some similar operation to reset the oven after disconnecting power.
If that does not work (often it does not), then testing will start from door lock switch, and will follow with the temperature probe testing. Both parts can be easily tested by running a controlled oven cycle with the part's contacts jammed.
I can be more specific on parts and testing procedure if you give me the complete model number of the appliance, as written in the service tag.
Here help finding your model number.
Regards.
Ginko.
Posted on Nov 11, 2010
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
What part is nt working when my magic chef 34mn37kxw clicks but will no ignite burner
Can you see a spark when that happens? It should be right in the vicinity of the bottom of the gas flame, and it should spark briefly every time you hear that clicking noise. That's what lights the flame.
If you see a spark, your burners may just need a thorough cleaning inside. If you do NOT see a spark but you still hear the clicking noise, remove the burner trays and try to find someplace where the little wire leading to each "spark plug" is permitting a spark to the stovetop instead of the burner.
Aug 04, 2014 | Magic Chef Kitchen Ranges
What can I do to fix my Wirlpool Gas Oven? Mo. # WFG361LVB
i would check my oven gas safety valve first
May 16, 2014 | Whirlpool Ovens
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can not hear a clicking sound and the ignitor is not sparking
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 30, 2014 | Whirlpool Ovens
Whirlpool Gold gas stovetop ignition stuck to on
Pull the knobs off and use a hair dryer blowing down the gas valve stems to dry out the spill. They should be fine once they are dry.
Jan 01, 2010 | Whirlpool Gold GW399LXU Gas Range
Igniters on stovetop work intermittenly model #cgs3760adq
You didn't say how old the appliance is but:
Check the spark gaps at all of the ignitors at the burners and also be sure everything is as clean as possible. The ignitors have a service life.
If the problem persists, there could be an issue with the control board.
Dec 12, 2009 | Kitchen Ranges
Stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
May 29, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Whirlpool Electric Stovetop Repair Issue
no replacement only option or use as is shouldn't cause and problems
Nov 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
nothing you can do short of replacing top, which depending on age may be a cost prohibitve option
Nov 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
