Question about Car Audio & Video
Ford galaxy central locking problem
2000 Ford Galaxy, when central locking is activated the rear nearside door does not lock, any ideas?
It´s probably a cable problem. There are two cables between the motor in the door, and the control center. In my case one of the cables where cut of do to to many door openings. Every time you uses the door the cable bends. In the long run it cuts.
Posted on Apr 26, 2009
Previous posting was spot on .I had identical problem with my 99 sharan I removed the rubber gaiter that covers the cables between the door and the door pillar and discovered three cables had broken all at once. Just rejoined with connectors and now its all fine.
Posted on Jun 20, 2009
2001 ford galaxy rear door won't latch Can someone help
THE INSIDE OF THE LOCK MAY BE IN THE LOCKED POSITION USE A SCREW DRIVER TO SEE IF YOU CAN OPEN THE LOCKS JAWS IF IT'S OPEN THEN THE STRIKER POST ON THE FRAME HAS COME LOOSE AND IS OUT OF POSITION THERE AREN'T ANY 2001 GALAXYS SO ?
Mar 14, 2015 | Ford Galaxy Cars & Trucks
Galaxy 2005 o/s/rear door lock not working
YOUR ROD has fallen off or the Clip has broken... If the Solenoid is working correctly. No Matter, you have to take the Panel off to investirgate
Apr 12, 2013 | 2005 Ford Galaxy 1.9
Galaxy rear door wont open with handle
Contact your door installation service: there's a lock that has to be fixed
Jan 22, 2018 | 2001 Ford Focus
Ford galaxy central locking locks with key but when you open it it then locks it self again any ideas what cause is
remove the drivers door panel and check the mechanism ,often a squirt with a proper oil can with engine oil will soak in a lubricate everything curing the problem
Sep 13, 2012 | Cars & Trucks
Central locking not working and air bag light flashing after fire.
A new friend? You can go to Autozone.com and register for free on their site. Then you can print wiring layouts and fusebox diagrams and try to reconstruct what is missing.
Insurance company. Comprehensive should cover this without a deductible.
I hope my solution helps.
Jun 08, 2012 | 2000 Ford Escort
Central locking problem with Ford Focus
Usually this is a faulty door solenoid. If the central locking activates when just the driver's door lock is used, then it's almost certainly the solenoid in that door alone. If you can activate the central locking via the passenger door, then it's a bit more complicated as more detailed diagnostics need to be done to isolate the fault.
Your Ford dealer, an automotive electrician and some automotive locksmiths can all quickly diagnose and fix this issue. It's easily a DIY fix, but you may end up replacing perfectly good parts and you can't then return them.
If on a very tight budget then you'll find all the parts you need at G.W.Bridges Breakers yard, it's an absolutely gigantic yard just near the Pease Pottage services at the southern end of the M23. However, you have no idea of the condition of used electrical parts like these so it's usually a false economy to fit anything other than new.
Hope this has helped you, if so please rate my answer.
Feb 24, 2010 | 2000 Ford Focus
Ford galaxy central loking failure problem?
Hi kifixya!
The doors lock automatically at road speed and must be unlocked with the unlock switch before they will open (with the exception of the driver's door). This is how they were designed to work.
To unlock all doors with the remote keyless entry, hit the button twice (like double-clicking a mouse); the first unlocks the driver's door; the second push unlocks the remaining doors.
Hope this answers your request, andgood luck!
-WildBill
Jun 16, 2008 | Ford V6 Pony Cars & Trucks
Car Audio & Video Logo
2,218 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
