Question about Epson ACULASER CX11NF All-In-One Printer
Automatic Document Feeder
My documents do not scan through. Rollers do not move. I get an Error Message that says C2011. I call Espon Tech Support. They say its a hardware problem.
  • Anonymous Sep 08, 2008
    Same problem. Epson support NOT helpful; only say it is related to the ADF system.
  • Epson Master
  • 1,879 Answers
Greetings,
Here try this, turn it OFF then locate the cable that is connecting the ADF and the main FLATBED scanner. Disconnect and re-connect it.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass?
Oct 16, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Oct 09, 2008 | Epson ACULASER CX11NF All-In-One Printer
How do you clean rollers on manual feeder
To clean the rollers or separator pad
1. Remove all originals from the document feeder tray.
2. Lift the automatic document feeder cover (1).
This provides easy access to the rollers (2) and separator pad (3), as shown below.
1 Automatic document feeder cover
2 Rollers
3 Separator pad
3. Lightly dampen a clean lint-free cloth with distilled water, then squeeze any excess
liquid from the cloth.
4. Use the damp cloth to wipe any residue off the rollers or separator pad.
NOTE: If the residue does not come off using distilled water, try using
isopropyl (rubbing) alcohol.
5. Close the cover of the automatic document feeder.8_29_2012_4_02_48_pm.jpg
Aug 29, 2012 | Dell 1135n AllInOne Laser Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Red/yellow line down left side of document when using feeder
the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jun 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
Jan 27, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
Thanks, Joe
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
Epson ACULASER CX11NF All-In-One Printer Logo
489 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
