Question about Sony KDF-50E3000 Television
Unable to figure out how to pull burned out bulb from tv and replace with new one.
  • princefamx4 Nov 11, 2010
    Thank You! this tv has been sitting for awhile now because I did not have the proper information for fixing it but you saved me an enormous amount of money by not having to take it to a shop, thanks again for your advise, I really appreciate it.
  • 10,594 Answers
There is lamp door at lower left side if you check KDF-50E3000 tv from rear, remove lamp door to access lamp.
Lamp replacement procedure is written in user manual with exploded views, click Sony Support link to download user manual copy and check page-43 for more details.
Thanks.
Posted on Nov 11, 2010
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
How do I replace the headlight bulb in my chevy malibu?
Open the hood. There is an electrical connector going to the headlight bucket assembly. Turn the connector counterclockwise and pull gently. The bulb is attached to the connector. Pull the bulb out of the socket and replace with new bulb. Be careful not to handle new bulb with greasy fingers or hands if bulb gets soiled wipe down with alcohol. Halogen bulbs burn very hot oil from your skin will shorten the life of the headlight bulb
Apr 08, 2011 | Chevrolet Malibu Cars & Trucks
I can not figure out how to get into the rear light bulbs (Stop light, etc). The manual says to remove two (phillips) screws to disengage the housing from the body. There's even a a picture. However, on...
To access the rear lights, you access them from inside the trunk. Pull down the carpet at rear of trunk near latch. There should be the screws the manual is referring to. Once you locate and remove all screws, gently pull the light assembly away from body. Replace the needed bulbs then gently push assembly against the body, replace the screws and set carpet back in place.
Nov 14, 2010 | 1995 Toyota Camry
I can't figure out how to get my 2003 Tundra taillight assembly off . I have removed the two bolts inside the tailgate area but it is still attached to the fender on the other side of the assembly . I have...
Unscrew the screws that are securing the brake light cover to the body of the Tundra. Pull the brake light cover off the body of the Tundra. Place the screws in the brake light cover and set it on the bed of the truck. Pull the burned-out light bulb out of the light fixture and discard it. Insert the new brake light bulb into the light fixture. Pump the Tundra's brakes to make sure the new bulb is working correctly. Replace the brake light cover on the body of the Tundra and replace the screws.
Sep 09, 2010 | 2003 Toyota Tundra
Can anyone help me figure out why my 91 civic running lights wont work. Checked fuses and replaced all bulbs??
The head light switch is bad,or the fusible link,either on the starter,or a positive battery cable junction,has burned out,it will pull apart like taffy if it is burned out.
Oct 06, 2009 | Honda Civic Cars & Trucks
Cant figure out how to get old bulb out of the tv
I just did that. Unplug the TV then pull of the panel below the screen (pops off)The you will see on the left single screw to a door like opening. Remove that screw and then look inside. You will be a handle and that part is screwed on. Remove the screws that pull outwards. Be careful as the lamp has mercury iand lead in it and you will need to dispose of it properly. Then remove the lamp and put on the new one. Do not touch the lamp with your fingers, use the glove that is usually provided with it. After that just push the lamp back in put in the screws, then screw the door like opening back on, pop the cover back on. You are now done.
Apr 02, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Blue half moon shadow on top of screen
We had this same problem with our 60+ inch Hitachi. Except our tv had a red hue in the center of the tv before we replaced the bulb and then the blue hue joined the red one after the replacement. It ended up that our light engine was defective (which is an extremely common problem in Hitachi tvs). You should read through some of the forums on here to see if you can find your solution exactly (that is how I figured out my problem was our light engine). You might have the light engine problem also, but I am not sure since you don't have a red hue. Hitachi pays for the replacement light engine part (worth $1200). I just finished the process and now my tv is like new. If you want me to go more in-depth with the light engine repair process let me know.
-kdubb
Nov 20, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Burned out headlight/bulb bmw 1991 325i 2dr
It's a bulb replacement. If it's anything similar to my Audi, there is a cover on the back of the headlight housing that you pop off. Then you can reach in, pull the wire connector off the bulb, and unclip a metal retainer over the bulb, and pull the bulb out. Installation of the new one is the reverse. Just be SURE not to touch the glass part of the bulb. Skin oils can cause a halogen bulb to burn very hot and burn out very quickly. If you do touch the glass, wipe it gently but thoroughly on a cotton cloth to clean it off before you install it.
Oct 31, 2008 | 1991 BMW 3 Series
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
Sony KDF-50E3000 Television Logo
293 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
