Question about Mitel 5220 IP Phone
On the Mitel 5215 IP Phone. I was updating the firmware, and my power went. Now I get an error "File not on Flash", and the phone resets. How can I fix this.
    Sergeant:
  • 378 Answers
I'm sorry to have to tell you this. There are two causes for this. But the solution is the same. The causes are either the phone was power cycled while it was getting it's firmware updated. Or the phone falls into the category of a limited flash module. The limited flash module only allows the phone to be updated only a few times. The 5215 has been notorious for this problem.
The solution is that the phone will have to be repaired or replaced.
Posted on Apr 15, 2011
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
I am trying to use a Plantronics CS70N headset with my Mitel 5215 IP Phone. I have the headset plugged into the headset jack on the back on the phone, but there is no head set button. Is there some...
First remove the headset cord from the headset jack. That is only used for corded headsets. Plug the short cord into the jack where the curly cord had been plugged into. The curly cord is now going to be plugged into the base of the charger where the picture is of a handset -- the curly cord goes there. There is a A/C adapter that is plugged in to base that is now plugged into the wall.
Good luck from Headsets Direct!
Jun 29, 2011 | Mitel 5215 IP Phone
Which pin on the network cable uses the voltage that power the IP Phone Mitel 5215
Though I can not confirm the phones voltage requirements, since all the phones I have worked with use 24vdc and passive POE (mode B in the Wiki link) here is the information Link
Feb 28, 2011 | Mitel 5215 IP Phone
My IP mitel phone 5324 phone gives an error message option 128 missing
the DHCP server or your network switch isn't configured properly. I hope by now your network admin or vendor has gotten this problem resolved.
good luck,
Mark
Jan 27, 2011 | Mitel 5215 IP Phone
When mitel 5234 is switched on it hangs at option 128 missing
I hope this has been resolved by now by your IT department or Phone vendor. Option 128 is a DHCP option and should be set up by them.
good luck,
Mark
Headset doesn't work when plugged into Mitel 5215 IP Phone jack.
You need to have a Headset button added and press it... or dial the headset on code. Contact your system admin or vendor to have the button added or to get the codes. This is something you can't do from the phone.
Jun 30, 2010 | Mitel 5215 IP Phone
DHCP DISCOVERY - USING OPTION 128 ERROR ON PHONE
The network switch isn't set up properly.Contact your vendor or network admin for setting this up properly.
May 26, 2010 | Mitel 5215 IP Phone
Trying to change passcode on Mitel 5215: worker has left without letting us know the code! Have put phone IP address into IE address bar but only get "page cannot be displayed". How do I access...
The voicemail passcode. It's a 5215. I read the manual that says you can reset passwords by putting the phone's IP address into your web browser, but that just gives me "page cannot be displayed". Don't know what to do next.
Sep 15, 2008 | Mitel Lands Phones
5215 5220 and 5224
The Mitel IP phone downloads its firmware from the 3300 ICP on startup, You need to spesify what the phone is doing, ie does it start up at all or is the phone Dead,
If the phone does start it might have the wrong settings in the phone preventing it from finding the 3300 ICP, There is a Default to factory setting by interupting the phone on bootup.
Dec 07, 2007 | Mitel 5215 Corded Phone (50002817)
Mitel 5220 IP Phone Logo
281 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
