Acer XD1250P DLP Projector
I have linked my laptop previously to other projectors - however it does want to display what is on the screen using the Acer - i have used the Fn / F4 function - without success, we are on windows XP,please assist,tnx paul
  • 682 Answers
Please switch your laptop on first and then your video projector and try fn/f5 orf6 orf7
Posted on Jun 17, 2008
Windows 7 acer laptop but cant display anything in my projector
use some fn with function key in your laptop to enable your output for projector
May 17, 2012 | Da-Lite Acer X1210K - Dlp Projector - 3D...
Cannot get screen to come up utilizing INFOCUS media projector
check whether the connections are proper that is any loose connection
Jun 19, 2008 | Acer Aspire 3000 Notebook
Connection with laptop
1)Plug in either the vga or dvi into both the projector and the laptop.
2)Plug in the power cord to the projector,then turn the projector on.
3)Once it has past its warm-up period,find the function key on your laptop.(Fn)
4)Along the F1,F2,F3 ect keys,press find the one with the picture of the display.
5)When you have found it,hold down Fn and press the display key down until it clones the laptop and projector.
Jul 02, 2010 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
I own a Optoma EP709 dlp Projector and have had no problem until recently. I have used a hp laptop Vista based computer. I can no long toggle (fn F4)successfully so that the view is shown on the projector...
this is a shot in the dark, i don't have a projector to hook to my laptop, but i have hooked it to my tv and actually had to right click on the desktop in an unoccupied spot and go into the display settings to get my connection between both, it is probably similiar for laptop to projector.
May 20, 2010 | Office Equipment & Supplies
The picture on my laptop doesnt want to show on the screen through the projector, it only shows the acer screen
start your laptop first and then your projector------try to press fn in laptop with combination of f3 or f5 or f7twice every time you try it.
Dec 27, 2009 | Acer XD1150 DLP Projector
What settings should I use for acer x1260 to dell d520 laptop? Projector says "no signal" - have changed avg cable - no difference.
The max resolution on the projector is 1024x768. But the problem you're having sounds suspiciously like the laptop not sending out a video signal...you have to *tell* the laptop to send out an image to an external display. On one of the function keys, like F4 or F8, there will be a small TV screen symbol. You have to press and hold "alt" and then press the key with the symbol. The initial setting is obviously for the laptop only. When you press the keys for the first time, you tell the laptop share the picture with an external display (your projector). Press the keys a second time, and the laptop ONLY displays an image from the projector. And, press the combination again, you're back to just the laptop.The DLP projector should have a menu selection for "auto" under the input menu...that is the easiest and most trouble-free setting. Whatever you connect to the projector, it automatically seeks out the signal and connects to it.---Rick
Sep 06, 2009 | Office Equipment & Supplies
I just purchased an Acer X1160 Projector and obviously am not savvy enough to understand what to do to make it work. When connected to my HP Laptop I get the image of my screen saver, but cannot get...
Your computer is probably using the projector as a second screen instead of displaying a copy of the laptop screen.
The quickest way to confirm is to try moving your cursor (mouse) off the right-hand side of the screen. Does it then show up on the projector? If so, then you can grab and move windows back and forth between the two screens.
If that solves it for you, please be sure to click the thumbs-up.
If not, add a comment and I'll try to explain
Sep 02, 2009 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Acer Aspire 1642 WLM not showing with projector
Try other F keys..other wise try Ctrl+alt+function key
Dec 08, 2008 | Computers & Internet
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
No Signal
Try it with 75Hz for the second monitor and use the VGA input.
USB/serial is only for configuration.
Thomas
Feb 19, 2008 | Acer PD100 Multimedia Projector
164 people viewed this question
k24674
jasbo
jasbo
