Question about LG Flatron L1752TX 17" LCD Monitor
Se giro la pantalla 180 grador como lo vuelvo a resstablecer
4 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: please
Hola.., parece su panel están defectuosos... reparado le costará lotes de $$$... Simplemente comprar uno nuevo... salvado el headached y $$$... Tienen un buen día!
Posted on Oct 07, 2008
bbl242003
  • 1637 Answers
SOURCE: ¿como ver la pantalla donde
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
bbl242003
  • 1637 Answers
SOURCE: hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Posted on Jan 24, 2011
Compr? un Radio Kenwood KDC-X300,cuando programo la hora,la fecha,dem?s funciones,apago mi carro,lo vuelvo a prender,el radio aparece en standby┬┐?lguien de ustedes me podr?a dar una respuesta?
Mi Espa?ol no es my biene ,perdone. Suena Como que lo tiene connectado all ignition solamented. Se nececita conectar el alambre de Acc. A la batteria directamente Para que Guarde la memeoria . Ay beses que se Idica el alabre en question con color azul. Hope it helps Buena suerte,
May 16, 2016 | Cars & Trucks
Zte n9511 la pantaya esta negray no se puede ber nada
Lo primero seria buscar en Google "Como hacer ZTE N9511 nuevo de f?brica". Si puedes ver videos mucho mejor. Esto lo que hace es entrar en una secci?n del celular conocida como recobrar, o recovery en Ingl?s. Si el celular prende, y logras acceder al recovery, que se pueda ver la pantalla, entonces puede ser una falla del SO (Sistema Operativo). Mediante el recovery puedes hacer nuevo el celular como si fuera de f?brica, o sea, como cuando se compra nuevo de la tienda. Esto repara el SO, haciendo que el celular vuelva a trabajar.
Este video es el que mas se asemeja a tu modelo.
Apr 02, 2015 | ZTE Cell Phones
COMO DESBLOQUEAR TELEFONO PANASONIC
Hola!, si miras en el telefono, si te fijas hay un boton redondo como debajo de la pantalla y lo presionas por aproximadamente 2 segundos se desbloqueara. Buena Suerte!
Jan 13, 2014 | Panasonic Lands Phones
Mi n-97 no enciende para nada y no se como solucionar mi problema
Hola estaba usando mi nokia n 97 y se apago y n prendio mas lo enchufo para cargar todo y prende la lucesita como que esta cargando pero la pantalla no hace nada
Sep 05, 2011 | Nokia N97 Cell Phone
La pantalla se pasa y luego se pone negra
gracias a juan , tambien me solucionaron el problema de mapas argentina lo tenia parado como 12 meses mi gps y al fin me lo solucionaron la gente de http://www.mapeogps.com.ar
Jul 29, 2011 | Magellan eXplorist 500 GPS Receiver
COMO REINICIAR CAMARA DIGITAL R727?
Qué te dejó ir a su menú? y si lo hace y luego ir a descansar menú de introducir la contraseña (si se necesita) y haga clic en , perova a eliminar todo lo que en la cámara .... o eso es lo que hice. ifuente una tienda de cámaras que lo tomó y lo arregló, me *** la espalda y tuve mis fotos y mi cámara estaba bien. que me ha pasado 2 veces before.it me costó alrededor de 20 dólares
o
Saque la batería de la cámara durante 5 minutos. Vuelva a instalarla batería y debe tener reinitiallized
Jan 12, 2011 | HP Photosmart R727 Digital Camera
Como puedo cambiarle la carcaza ami motorokr z6 yo misma? es q se le rompieron unas partes xq se m callo al piso, y ay q compre una carcaza nueva me gustaria saber si m pueden explicar como la puedo...
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
Jun 12, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
TENGO UN MITSUBISHI DE 95 , LA TRANSMISION 1.8
quizas necesita revisar sensores de transmision,tambien el nivel de aceite,ya por ultimo quizas sea que ya empezo a resbalarse y va a necesitar una transmision nueva o usada.
Sep 19, 2009 | 1995 Mitsubishi Mirage
LG Flatron L1752TX 17" LCD Monitor Logo
21 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
