Question about Roper RTW4100SQ Top Load Washer
At the end of each spin cycle there is a loud rumble from the drum area - has been going on for 3 mos and is getting louder
  • J A Underwood Nov 18, 2010
    about the noise from the roper wash machine - took the machine apart and checked on the brake system and the noise - I found that a plate, triangle shape - that was held in place by 3 pins had worked loose and only 1 of the pins was still there being held from falling out by plastic caps at each pin. It appears to me that these kept everything centered on plastic tabs . If I,m correct or even if not I still need 2 more of these pins and cotter pins. They are smaller than most pins of this type that I usually find and haven't found any at hardware stores. Any ideas on these pins and plate being the problem? I haven't reassembled it yet and would not care to do this again if possible. Thanks for the info so far - how would I find a parts breakdown if possible.
    President:
  • 1,891 Answers
When the spin cycle ends / the brake goes on and it is stopping a tub and a wet load of clothes / and it was spinning at about 550 rpm . so to stop it in 8 to 10 sec it's working the system perrty good. . what has happend is the tub drive block has warn out . this is located at the top of the spin shaft just under the agitator . its not a expensive repair but should be done by a tech that knows whirlpool . mm hope this helps / feed back please . and thank you for ysing fix ya ..
Posted on Nov 12, 2010
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
Sounds louder than normal, in spin cycle.
Could be the drum bearing failure. Turn the inner wash drum by hand. If it feels rough or makes a rumbling sound would mean that the bearing have failed.
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud spin cycle noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 16, 2010 | Kenmore Elite 45986 Front Load Washer
Drum Banging When Spinning
Bearing problems normally cause rumbling noises as the drum spins which gradually get louder.The bearing are located between the inner drum and the outer case.It might have got misaligned due to overloading.Repairing these is very involved and requires removing and stripping the drum.
Apr 05, 2010 | Hotpoint Washing Machines
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Loud grinding noise that should go way after one complete cycle. After 3 cycles it just gets louder and louder.
Remove the lower spray assembly and clean out the sump area.
Probably broken glass or a loose screw got in there.
Apr 20, 2009 | Dishwashers
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Roper RTW4100SQ Top Load Washer Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
