Question about Makita 9924DB Electric Sanders & Polishers
After you remove the 2 screws from the dust collector cover, I can not remove the cover is there a latch or something I am missing to remove this cover? I need to remove to replace the dust bag....
  • Makita Master
  • 7,733 Answers
Look at eReplacementParts.com and the parts diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
  • halfpricesig
    halfpricesig Jan 11, 2012
    just slip a flat screwdriver under one side of the bag clip and lever it off, its just a very tight spring fitting.
How to change the filter and wash
It you have the ball. Look on the side and you will see two small cut outs. Just screw it off and you will see the filter also there one on top of the The trash Collector. If you have the older model. Remove the trash collector and pop up the flat base under it. Wash the filters with warm water and let dry for 24 hours.
Apr 26, 2016 | Dyson DC07 Animal Bagless Upright Cyclonic...
I need to replace the dogs but I cant get the dust cover off of the agitator.
Shoot some wd40 or some other spray lubricant around the edge of the dust collector and let it soak for 30 minutes and the you can take a pair of pliers and grab one of the ears closest to the edge and pull up. There is a rubber seal that has dried and gotten stuck. That should removemthe dust cap and allow you to access the 1/2" nut to remove the upper half of the agitator and replace your dogs.
Nov 22, 2014 | Washing Machines
Cannot get door to unlock
Remove the four screws from your dispenser, remove cover, there should be a plastic string, either red,yellow or green pull on it and the door should open. Then remove the four screws aound the door 2 aound door hinge then the other side, remove the front cover, it looks like a small goal post. Remove the the 5/16 screws under the lid. Raise top then you will see your latch assembly. oberverve your latch see if anything is broken. You can order a new latch assemby.Part#22004435 list for about $115.00
Apr 04, 2014 | Maytag Neptune MAH5500B Front Load Washer
Removing lid lock switch on cabrio washer
Hi
To get to the lid lock you must raise the cover To raise the top you unscrew the top screws in the back, ( the ones that hold the smaller galvanized piece of sheet metal behind the control panel). There is also two clips on the sides of the back with 2 screws in each, remove the top ones. You should be able to slide the cover forward while lifting. It will hinge on the 2 clips. Then prop the cover to keep it open. Under the cover are 2 screws that hold on the latch. Under the cover towards the back there are 2 spring clips that hold down the top user control panel. Squeeze them to release the panel. Follow the wire from the latch to the motor control module and unplug the plug. Remove the latch. Reverse to reinstall a new one.
Robert
Oct 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Message says airfow blocked, turns on for about a minute then shuts off
1. Remove the air intake filters on your DLP projector. As explained by InFocus, a manufacturer of LCD and DLP projectors, each DLP model will house the air filters in a different location. However, for most DLP projector products, the filters are accessible by unclipping a simple plastic latch.
2. Wipe the air filters with a small cloth dipped in rubbing alcohol.
3. Blow compressed air into the unit's vents. This will force some internal dust out of the DLP projector, but you may still need to open up the unit for additional dust removal.
4. Unsnap the main cover from your DLP projector. Because DLP projectors need periodic lamp replacement, the main cover is rarely secured with screws or bolts. However, if the DLP projector's cover does not snap off, then you'll want to inspect the unit for possible screws or an alternate release latch.
5. Reach in and remove visible dust globs with a paper towel. Be careful to avoid touching the lens, as fingerprint smudges can diminish DLP projector image quality. If you accidentally smudge the lens while picking out dust blobs, wipe the lens with a dry, lint-free microfiber cloth.
6. Spray compressed air into your DLP projector to remove any lingering dust particles.
7. Close up the projector and reattach the filters.
Sep 26, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How to open cover mobil nokia n70
There are 6 latches all in all. 2 in the bottom part, 2 about 1/4 for the top (in line with the top of your screen) then 2 in the top part. First remove the bottom 2 latches. I would suggest to use a jeweller's flat head screw driver or similar. Then slide the screw driver up one side to the latch that is about 1/4 from the top - it is in line with the top of your screen, this latch should pop off. The cover is fairly strong but do be be a little careful about breaking it.
Then the other do the same on the other side, after that every thing else is easy, pull the front cover carefully from the middle latches then slide the cover upward. If you do all this carefully then you will have successfully removed the front cover.vote me if this works.thanks!
Jun 16, 2010 | Nokia N70 Cellular Phone
Replace 1984 f150 tailgate latch
Hi!!
Open up tailgate, remove screws holding cover plate to get access to latch, remove the latch 2 fastening bolts and the 2 rods and install new latch.
Don't forget to rate this answer, Good Luck.
Apr 11, 2010 | 1984 Ford F 150
I need info on removing rear door panel on 2004 Grand Prix
there are Hidden Screws you have to Look Hard for Small Covers to them and Mostly there are SNAPS along the BOTTOM and SIDES Screws are Around the HANDLE and Latch
Dec 26, 2009 | 2004 Pontiac Grand Prix
Makita 9924DB Electric Sanders & Polishers Logo
144 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
