Question about Kenmore Washing Machines
I have model 110.28522700. It shakes more than it should during the spin cycle, and sometimes makes an awful raket when it shuts itself down and rotes to a stop. It is not due to an unbalanced load but a heavy load adds to the problem. We have cycled it empty and the some of the shaking still occurs. Mike
    President:
  • 1,891 Answers
The problem is either the centering springs or the floor . if on a wooden floor it may need to be stronger . ck the legs also as if there extended all the way it hard too support the machine . in this case lower all 4 to the lowest you can and lock the lock nuts so they do not wiggle in the thread . . the back may be self leveling and if so just adjust the front ones . mm hope this helps . and thanks for using fix ya ..
Posted on Nov 13, 2010
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
My currys essential washing machine beeps during cycle and stops help
Remove the power for sometime , check if the spindle is FREE and moves. , Remove the back and under side to inspect for any damage to the motor or drive. check the power lines, check on the motor CAPACITOR. Now when powering check the VOLTAGE to the motor. if this is low or absent then the program controller unit is faulty.
Dec 31, 2012 | Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Spins during agitation makes noise
Welcome to FIxya
I would check the belt and i would also check the bearing
hard to help you out with out seeing it but i would check those first ....
hope this helps out have a good day :)
Oct 29, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
