Question about Ryobi Garden
My daughter has a Ryobi 790R "EZ" leaf blower that just won't start. I have cleaned the carburator and used "Quickstart" but it won't even cough. There seems to be a spark but I wonder if the unit has the correct spark plug. Can you tell me what it should be? Any other ideas? John
  • 1,040 Answers
Even though you have cleaned the carb., I am going to instruct you to do the same thing. I have a couple of Tips that makes all the difference in the world!
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
If you need further assistance, just let me know.
Good Luck!
Jim
Posted on Nov 13, 2010
NEED THE PART NUMBER FOR THE SPECIAL TOOL THAT CAN TURN THE CARBURATOR MIXTURE ADJUSTMENT SCREWS FOR A RYOBI MODEL NUMBER RY28040
if you get a small flat edged screwdriver or a tuning screwsriver for lelectronics they will both work the same. you shouldn't need a special tool for that.
Jul 01, 2011 | Ryobi Garden
Very hard to start, i pull and pull and pull on the cord but it wont start i do prime it every third pull any ideas?
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can agitate it do so to help the gas disolve any clogs.
Clean the ports with the spray cleaners to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 07, 2011 | Ryobi Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Ryobi 31cc 18'' 790r ez has no power
You have done just about all you can do with this machine give up and buy a new one
Jul 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 790r. I have worked on small engines a long time. I took the carb apart and cleaned it-it set for 2 years. I reassembled it and now it starts but when I pull the throtle it dies, or won't rev up....
It may not be your carb at all. I had a Stihl that was doing the same thing. I ended up replacing the fuel lines and the filter (in the tank). It ran great after that. Hope it helps!
Jun 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What is the correct fuel mix for the ryobi 790R trimmer?
The window ratio should be fine between 40/1 to 50/1.
Reduce oil ratio by increase gas part if some unburned oil can visible from the exhaust.
Someone else could have a better voice on this matter..
Jun 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi 790r weedeater and i need the gas tank off . How do I do this?
On the 790R you will have to remove the carburetor and the four screws of the plastic housing behind it. The gas tank will then slip out.You will need to replace both the housing and carburetor gaskets.
Hope this is of some help, Lamar
Jun 20, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
161 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
