Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Help i need a setup dic for the canon super g 3 I need an installation disc for the all in one printer. Canon mf5550.
  • vicky7001 May 11, 2010
    please i need a driver to install my canon mf3200 printer
Who do i go about to change an Ip Address on the following printer.
Canan MF3200
Posted on Jul 14, 2008
  • 134 Answers
  1. Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=9516
Posted on Jun 17, 2008
Driver Canon mf5550
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550
This is all they got.
If they don't have the driver for windows 7, you will be stuck with the possibility of trying my suggestion for installing.
On Windows 7, go to Control Panel then Click on Programs.
Below Program & Features, you will see "RUN PROGRAMS MADE FOR A PREVIOUS VERSION OF WINDOWS"
A new window will open up called PROGRAM COMPATIBILITY.
Follow the instructions, and add a driver for the previous version.
If it works, then you are all set.
If it does not, then you are better off getting another printer.
Eventually, I had to sadly get rid of this printer. It was a great and wonderful printer, and I was sad to see it go because of driver compatibility issues since I got another brand new computer that does not work with it.
IMPORTANT NOTE: 64bit versions are even harder to make it work with this printer.
Hope it helps! Good luck.
Aug 29, 2012 | Canon imageCLASS MF5550 All-In-One Laser...
Cannot install drivers for Canon MF5550 on Windows 7 64 bit O.S.
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://www.makeuseof.com/tag/3-resources-windows-7-printer-drivers-printer-working/
Jan 07, 2011 | Canon imageCLASS MF5550 All-In-One Laser...
Cannot run the Canon MF5550 printer (lack of an appropriate driver) running Windows 7. Any solutions?
Drivers for your printer and operating system can be found here along with Guides and Manuals:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550#DriversAndSoftware
Uninstall your old driver; download the new driver for your OS and install.
Trust this is helpful. Please vote. :)
Dec 16, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
I have a canon MF5550 printer that I am trying to use with Windows Vista. There is no compatible printer that I can find. What is recommended?
Canon isn't supporting this printer for Vista. You can try using the driver for XP. Available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550?selectedName=DriversAndSoftware#DriversAndSoftware
You may need to use the Compatibility Mode on the installer as well as the driver. (Right click on the .exe and select Properties. Then go to the Compatibility Tab and check the box for the Run this program in Compatibility Mode and choose XP in the adjacent drop down.) Then right click again on the .exe and choose Run as Administrator to make sure the UAC allows the installer to work.
I hope this helps.
(a generic printer driver may install when you plug in the printer without installing the software first. If this happened you should uninstall that driver before trying the Canon version. If the Canon driver doesn't work, the generic printer driver in Vista will probably let you print but you may lose the scanner features. Please note that the buttons may or may not work to launch the software on the computer. Try opening the software and initiating scans from the computer.)
Jul 22, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
How can windows xp install this printer in
probably not ... go to www.canon.com/support and get the driver you need to install this device on your computer, if it is supported under XP.
It is XP compatable, RIGHT? Check the microsoft compatability list for XP operating system.
Jan 15, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
I have just upgraded my computer and it came with Vista. I cannot find a vista print driver for a Canon MF5500 imageClass series. Can anyone help me?
Should have come with a installation disk to install the driver .
failing that,check the manual for the printer and visit the Canon web site.
Oct 02, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Canon MF5550 printer driver for Windows Vista
I just found this solution TODAY! After trying for a whole year to fix this thing... It was right at my face the whole time!!!!
1) Uninstall your old Canon MF5550 driver.
2) Reboot your computer
3) Download the Canon MF5550 driver Windows XP version.
4) Open your Vista Control Panel, then click on PROGRAMS (not on Uninstall or something else...)
5) bellow "Programs & Features", click on "use an older program with this version of Windows". Follow the wizard.
6) Locate the program manually. (If you need to search the folder where you downloaded your Canon driver, just go to search file on C. It will probably download on your desktop or Downloads)
7) Open the MF5550 Folder where you downloaded the driver, and click on the setup.exe file.
8) Choose on the next screen Windows XP
9) If you need to change the display settings, go ahead. But I didn't change anything. I just clicked NEXT.
10) Fill in the box: RUN THIS PROGRAM AS AN ADMINISTRATOR and click NEXT.
11) Click Next again and let Windows Vista do its job.
12) If it worked... just click yes and finish. If it didn't, click NO and run it again.
I AM SO HAPPY THIS THING WORKED!!!
Let me know if this worked for you!!!! I know I've looked everywhere for this solution...
email me at music2harvest@msn.com
GOOD LUCK! GOD BLESS!
Apr 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Lost software
go to the link below and pick out your machine and you will find the drivers. hope this helps.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jan 05, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageclass printer 5550
I have crazy feeding/paper jam problems with my MF5650.
Oct 06, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
93 people viewed this question
old marine
old marine
