Question about Sharp AR 201 Copier
Error code I need to know what a U2 error code is and how to reset it to make the machine work again, any info would help
Hi , press these buttons on the copier to see if it will clear the problem: clear, interrupt, clear, then enter the number 16 then press start, it might clear the problem as it will re-start and possibly clear the hung code Iwill look back later to see how you did. Ko
Posted on Jun 23, 2008
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
How do I correct error U2-40 on Sharp AR-M236
U2-40 is the error code for the toner cartridge.
It indicates a fault with the chip in the cartridge.
Try entering simulation mode to reset the error first, to do this make sure the machine is in COPY mode.
Then press the following 4 keys in order: #*C*
then enter 16 & press the copy start key.
Then follow the instructions on the screen to reset U2 error.
When complete, press CA key to exit simulation mode.
If the error re-occurs then the toner cartridge will have to be replaced & the machine reset again as above.
Hope this helps.
Dave.
Jan 16, 2017 | Sharp Office Equipment & Supplies
Sharp mx-3111u error u2-91
The error you have is a miscommunication between the PCB's within the copier.
Make sure the machine is in COPY mode.
You need to press the following 4 keys in quick succession:
#*C*
Once in simulation mode enter 16 & press the copy start key.
Then press EXECUTE, then YES then press the CA key.
The machine will then restart.
IMPORTANT! Do not enter any other simulations as this could render the copier inoperable.
This will reset the U2 error. If the code is still there after resetting the machine then it is likely you have a PCB failure which will require the intervention of an authorised dealer.
Hope this helps.
Dave.
Dec 12, 2016 | Sharp Office Equipment & Supplies
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
My sharp ar150n shows u2 error code and wont work please help
U2 is a problem in the laser unit, if after resetting it is still showing then you need to get it replaced.
Nov 30, 2009 | Sharp Office Equipment & Supplies
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Sharp AR 201 Copier Logo
213 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
