Question about Disteck P4204TWHD Television
No power... i tried that.. doesn't work.. had a repairman come. he says the audio module is out... looking for replacement part and where i can get that part.
  • 1,879 Answers
Hope this helps
Disteck International
[USA] Address:
3660 Wilshire Blvd. Suite 820 Los Angeles CA 90010 USA Phone:
1-213-2529393 Contact name:
Robin Lee, Assistant Manager
Posted on Jun 17, 2008
  • 13,433 Answers
For replacement parts you would have to contact the manufacturer.
My dewalt radio dc012 blow fuse in power board,fuse replaced and radio work,after while fuse ok but radio again doesn’t power up
I read this as this: You replaced a blown fuse, the new fuse still looks good but the radio no longer works.
First test the fuse, if it checks out OK then something else has blown in the radio, I check the power supplies first, giving it power and seeing if everything there is still working as it should.
Nov 01, 2017 | Dewalt Audio Players & Recorders
I have an ilo 32 inch tv and after its been on for 30 minutes or so the sound goes out, what can i do to fix this ?
tried to hooked up a powered pc speaker in the audio output jack. if the sound doesn't goes out after an hour that was mean the cause is bad amplifier circuit. if the sound still goes out you have bad sound processor circuit. this case can be hand held with a trained tv technician. if you don't have any idea just leave it to qualified repairman.
Sep 05, 2012 | Televison & Video
Mini mac a1176 won't boot up (no signal being received by monitor)?
It will probably be easiest to replace it, but before you do go exploring to see if you can find an easy fix.
How to get inside:http://www.ifixit.com/Guide/Installing-Mac-mini-Model-A1176-Top-Housing/1103/1
Once inside, look around for anything that appears burnt or disconnected.
Look at these tutorials:http://www.ifixit.com/Device/Mac_Mini_Model_A1176
Make sure what you have looks similar to the pictures. If you can find what is broken, you can replace it using these tutorials also.
Apr 28, 2012 | Apple Mac mini Desktop Computer Desktop
My problem is it doesn't seem to generate enough power to run 4G or DDR3 ram. I can't boot the system up with 2 sticks or RAM (4G) and it works fine with 2G. Had replaced the power supplier with...
are the ram modules of the same type/brand
you might have a faulty ram module or a dirty or faulty socket try alternating the modules to see if you get the same result
if only using the one module keep it closest the CPU central processing unit
hope this helps
Sep 16, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Power comes,but screen doesn't work. Repairer says no hope for repairing,replacing chipset will not work.
Try to reinsert the memory module/s if you have not tried it yet. If yes, you need to replace the whole motherboard and it should work again.
Hope this helps.
Jun 11, 2011 | Computers & Internet
Timer light blinks rapidly, set will not turn on...
well you could replace caps in the dm module they are 1000microfarads @16 volts there are 7 of them 99% of the time that works if not you have a problem with the e2p module which is also located in the dm this will definitley fix yiur problem
Jun 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Ice Maker Problem
The "ice maker module" is pretty vague. THere's lots of things that work together to make ice. Could be a bad motor, a bad solenoid (electric valve that lets the water in), a broken gear, a loose wire, or just frozen up. If you havent pinpointed the problem, you are probably wasting money buying a new "ice maker module". I'd advise looking for obvious problems (frozen/jammed, no water input, broken looking stuff) and if you dont see anything, call a repairman.
Feb 26, 2007 | KitchenAid KSRS25IL Side by Side...
Televison & Video Logo
57 people viewed this question
Top Disteck Televison & Video Experts
Electro Med Services...
Are you a Disteck Televison and Video Expert? Answer questions, earn points and help others
