Question about Maytag Kitchen Ranges
Maytag Glasstop Range Model #: MEP5770AAB, General 27134070AR, 100/240 VLT, 10.4KW/7.8KW The oven Temp is set and it runs for about 20-30 minutes and then we receive an F-1 error, a chime sounds and the oven shuts down. What type of probelm is this and what part, if any needs to be replaced? respond to temco@execpc,com Thanks for your help
  • 1,711 Answers
The F1 error means , Stuck touch pad.
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Here is simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
The ERC is the part no 6 CNTRL-ELEC
Part Number: AP4396964 made by WHIRLPOOL
In the following link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46492&diagram_id=639613#d639613
Posted on Nov 11, 2010
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Manual for operating a Maytag cooking stove model # MER5870BCW
Go to this link:
http://www.maytag.com/support/manuals_literature.jsp
Type in your model number: MER5870BCW
It will ask you what type of visitor you are. Select "Consumer"
Then where it says owners manuals BELOW the summary rt click the 1.890 mb flile and "save as" to your computer.
The link is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MEP5770AAB.pdf
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 26, 2010 | Maytag Ovens
Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 02, 2010 | Maytag MER5755Q CleanDesign Electric...
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Nov 09, 2009 | Maytag MER5775Q Electric Kitchen Range
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
136 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
