Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
I HAVE A 250 AIR COMPRESSOR TOWABLE THAT BLOW OIL OUT OF AIR LINES
virgils
  • 39 Answers
SOURCE: craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Posted on Oct 13, 2008
rayname
  • 70 Answers
SOURCE: Air compressor/ alot of air is coming out of the oil cap vent.
this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: there is oil in the air lines of our compressor
I would recommend soap (Dawn) and water. Then blow the air line out to dry them. I would not recommend a flamable solvent. You can make a water eductor using a tee and a small plastic tube and some fittings from the local hardware. you attach it at the compressor outlet and put the tube into a bucket of soap water. As you blow air through you hose you will **** up soap water and send it down the hose and out with the air. That should do it.
Posted on Apr 25, 2009
ollie reece
  • 1167 Answers
SOURCE: oil blowing out of the air line
thats your piston rings gone buddy thats all it can be
Posted on Nov 16, 2009
  • 54 Answers
SOURCE: have towable prestige model puts a constant 100
It is normal for these units to pass osme oil. If you have had the machine awhile, and think that the problem has gotten worse, start by changing the oil separator filter (inside the oil tank). Also check the scavenge line that dips to the bolltom of the serparator it must be unblocked. There may be a nozzle and/or strainer in the scavenge line as well. Make sure they are clear.
Posted on Nov 22, 2009
2003 Suzuki RM 250 blowing oil out of the breather line
Hi, Bob and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.kiwibiker.co.nz/forums/showthread.php/177158-Suzuki-Rm-125-black-oil-from-exhaust-and-breatherhose
How to fix leaking power valve Suzuki RM250
Suzuki RM250 Owner Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki
Jul 12, 2018 | 2003 Suzuki RM 250
I have a Ridgid 5 gallon stackable air compressor that when I shut the compressor off, all the air discharges from the tanks. Do you know what the problem is?
You don't say how old this unit is. I had an older one and it had a small rust hole in it's tank. Had to get rid of it because the tank was rusted bad on the inside. Also check all the lines as they could be leaking as well. Also the one I have now leaked air because the compressor was low on oil. I got compressor oil and its ok now. Do not over fill as it will blow oil all over.
Dec 05, 2017 | Ridgid Air Tools & Compressors
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Need to fix ingersoll towable compressor 250. Engine doesn't increase when using a tool
Sounds like a plugged control regulator, they control throttle position and compressor inlet valve position.
Mar 07, 2010 | Air Tools & Compressors
Have towable prestige model puts a constant 100
Nov 22, 2009 | Ingersoll Air Tools & Compressors
Oil blowing out of the air line
Nov 14, 2009 | Campbell Hausfeld 28 - Gallon Air...
2004 ford diesel blows white smoke. and drops of
look for block return lines- air leak in suction lines -block fuel line or filter - defective injection pump -inoperative glow plugs.
Jul 04, 2009 | 2006 Ford F-250 Super Duty
There is oil in the air lines of our compressor how to remove the oil from the lines
Apr 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman air compressor, oil build up in the air line
Oct 13, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
136 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
