You can load paper in both the Front
Tray and the Rear
Tray.
How to load paper in the Rear Tray
1. Fan paper and align four corners.
2. When loading paper, follow the instruction below
carefully.
Open the sheet feeder cover and pull out the
paper support.
Load paper with the paper's print side facing
up, aligning its right edge to the cover guide.
Note: Setting
Credit Card sized paper with the long-side down by mistake may cause
paper jam.
Pinch and slide the paper guide to the paper's
left side.
Open the front feeder.
Extend the output paper support.
Note: When loading legal sized
paper, make sure to close the stopper of the output paper support.
Switch the paper thickness lever according to
the type of paper you use.
- Left: When printing on the paper other
than envelopes or T-shirt transfers.
- Right: When printing on
envelopes or I have selected the front - ip3500_rear_tray3.jpg />
Ensure that the Power lamp is lit.
3. When loading envelopes, be sure the flap is closed and to
the left with the non-flap side of the envelope facing up.
top
of page
How to load paper in the Front Tray
Important:
Only 8.5" x 11" (Letter size),
A4 and B5 plain paper can be used in the front feeder
Note:
Before loading paper, be sure to flatten its four corners. Otherwise,
the paper may jam. When paper is curled, hold the opposing curled
corners and gently bend them in the opposite direction until the paper
becomes completely flat.
2. BefoI have selected the front - ip3500_load_paper_front3.jpglowing.
Extend the output paper support, then its stopper.
3I have selected the front - ip3500_load_paper_front2.jpg the instruction below with
care.
Load paper with the paper's print side facing down,
aligning its right edge to the right edge of the front feeder.
Note: Do not load
paper in the paper output tray.
Align the trailing edge of the paper to one of the
paper size marks on the front feeder.
Pinch and slide the paper guide to the paper's left
side.
Set the paper thickness lever to the left.
Turn on the printer and confirm that the Power lamp
is lit.
If the problem persists you may want to remove the printer and reinstall the latest driver located here just click the link and then make sure to select your current operating system:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip3500#DriversAndSoftware
Also if you still need assistance please let me know why it is that it matters which tray you are printing from. Most likely you can just keep both trays loaded and print away.
Thank you,
Lee
You can set the default paper source for all print jobs. Tray 1 is the default factory settings, only an installed paper source will appear as a menu setting. A paper source selected by a print job will override the Default Source setting for the duration of the print job. Check the word processor print settings, make sure that it matches with the printer paper menu settings. To do this you may click print and click on properties button. Click on the paper tab and you can set the input options like paper size, paper tray (source) and paper type.
For further assistance, please call Lexmark Technical Support.
Lee,
I will try the new drivers location you sent but the reason I only want the front tray is because it's my wifes printer and the only place to put it is on the top of her desk hutch. She can reach the front tray but has to stand on a chair (with wheels) to reach the back tray.
Thanks,
Dana
