Question about Swingline Heavy Duty Stapler 30 160 Sheet Capacity GrayBlue
Hi - I have a model 113 manual swingline stapler which is jammed - plus I have no idea how to load the staple into it - need to unjam it and then figure out how to actually get the staples into it! Thanks!
2 Suggested Answers
SOURCE: We have a Swingline 690
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Posted on May 10, 2011
How do I load staples in model 520e
Hello, Go to this website for a manual or call cust. support on this website. Swingline Manuals Swingline
Oct 23, 2014 | Swingline 520E Electronic Stapler Black
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Swingline Heavy Duty Stapler 30 160 Sheet Capacity GrayBlue Logo
973 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
