Question about Biostar K8M800 Micro AM2 Motherboard
Just yesterday my computer stopped booting and only gives a long beep tone every 3 to 4 seconds. Can you tell me the problem? (This is about a K8M800 Micro AM2 motherboard)
  • sabre700 Nov 11, 2010
    I did everything you suggesed including swapping to different memory that I know works. I am still getting the long beeps every 3 to 4 seconds.
    Jerome Rudy
  • 2,567 Answers
Check the RAM modules. They might be either defective or they are not making good contact with the motherboard. You can clean the edge connectors on the RAM modules as well as the connectors in the slots where you plug them using an electronic contact cleaner of the dry type (not the oily one). If this did not fix the problem, test your motherboard with a different RAM module & also test your RAM modules in another motherboard.
Posted on Nov 11, 2010
  • 4,281 Answers
For that open back cover of cpu then you can see motherboard. First make sure motherboard is not ground with cabinet cover.Reconnect RAM memory ,Reconnect pci card if any.Also reconnect processor and it's fan. Reconnect both connection to harddrive. Then check. Long beep always because of RAM memory so clean it or try with another ram memory then check. Let me know if you need further assistance.Thanks for using FixYa.
After turning on it turns off automatically after 3-4 seconds
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 07, 2012 | Computers & Internet
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
Cant turn my computer on and there is a yellow blinking light
How many blinks? Count and notice the patterns of the blinks (3 long blinks or 1 long blink followed by two short blinks).
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If all the above fails, you problem could be your Video Card or a motherboard issue.
Apr 14, 2012 | Dell Dimension E510 PC Desktop
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Mar 28, 2012 | Computers & Internet
Yesterday my computer stopped booting. Now all it does is give a long beep tone every 3 to 4 seconds. I've swapped known working memory, replaced cables to my drives , removed and reinstalled the CPU,...
make sure the RAM is seated properly
Test or Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your
(motherboard to hard drive)
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
hope this helps
Nov 11, 2010 | Biostar K8M800 Micro AM2 Motherboard
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
I have a MPC NetFrame 620 server . It bagan to
replace with a new card. The beeps are indicitive 0f failed hardware 2 beep 2 beeps = video card series of 3 beeps keyboard ,malfunction etc etc so whichever card now gives you one long beep you had better start there.....
Jul 28, 2009 | Computers & Internet
On starting my desktop(emachines e4216)the machine emits 3 beeps.
3 beeps - check the manual for the motherboard that you have or your computer manual and it should tell you what the 3 beeps means.
If you need to find out what motherboard you have you should either be able to use wcpuid or SIW ( google them ) and you should get the correct utilities ( if not post back and I can post some links )
I would also suggest ( as long as its not under warranty still ) to take the side off of the computer and give the inside a clean out using compressed air.
Has it got anything new hard ware wise that was installed as this might be sapping too much power and stopping it from booting ?
Apr 10, 2009 | Computers & Internet
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Biostar K8M800 Micro AM2 Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
